Sponsored by: Auxito
pinging
Old Oct 19, 2008 | 03:38 PM
jayrus544's Avatar
jayrus544
pinging
i have a 01 4.2l It pings alot under mild acceleration. Will seafoam in the gas help solve this problem? Any other thoughts would be very helpful too.thank
Old Oct 19, 2008 | 04:27 PM
galaxie641's Avatar
galaxie641
Highly unlikely. Try using a higher grade fuel to find out if that helps. If it does a motorvac might clean things out and stop it.
Old Oct 19, 2008 | 07:51 PM
jayrus544's Avatar
jayrus544
I've tried running prem fuel for two weeks or so. It doesn't make much of a difference.
Old Oct 20, 2008 | 01:02 AM
streethealer's Avatar
streethealer
Is your check engine light on? If you are running premium fuel and it is still pinging, I suspect that you are running lean and possibly have a vacuum leak or intake leak. The 4.2l engine is prone to intake gasket issues. Good luck.
Old Oct 20, 2008 | 03:01 PM
bokker's Avatar
bokker
hi, check on the v6 4,2 list and you will find a lot of engines have the same problem. search that forum and i think that ford gave no cause for concern. ps my 4,2 1997 also pinks badly but having 190,000 miles on the clock i am not at all worried. bokker.
Old Oct 20, 2008 | 03:07 PM
Ron W.'s Avatar
Ron W.
Well tell it to "Man Up"
Sorry man couldn't resist.
boyer669
Modular V10 (6.8l)
Aug 25, 2014 07:39 AM
jjurva
Dec 19, 2011 10:17 AM
Milwaukee1979F150
Oct 4, 2010 12:17 PM
MPDano
15
Nov 22, 2006 06:41 PM
jcandrew
3.0L V6
Jul 7, 2003 11:36 PM
