Bolts for mounting steering box
75 F250 camper special
2WD
Power steering
I need the bolts to mount the steering box onto the chassis. I think there are 4 or so???
Any idea where I can get them? LMC? Dealer?
Thanks.
Your best bet is to go to a nut and bolt shop. Around here we've got a couple places (Tacoma Screw and Valley Nut and Bolt). They'll have the right size and length available, as well as grade 8 and a flanged head. It'll cost probably 2 to 4 bucks a bolt, but they'll be the right ones.
carriage bolt
The larger sizes are called "shaker screen" bolts.
My '75 F150 uses plain ol' grade-5 7/16" bolts.
Alvin
carriage bolt
I was told the larger sizes are called "shaker screen" bolts. :)
My '75 F150 uses plain ol' grade-8 7/16" bolts.
My originals have the "grade-8 circle" on the head instead of the 6 radiating lines.
Alvin in AZ
Making square holes round won't weaken it any. :)
That's the way I'd'a prob'ly done it too. :)
Alvin in AZ
This is a very common occurance even when these trucks were brand new.
WARNING: When the bolts work loose, that can cause the frame to crack!
Ford changed the bolt design several times thru the 1970's, didn't help much.
3) 384737S2 .. Bolt-Power Steering Gearbox to Frame / Grade 8 ~ 7/16" -14 x 3 15/16" ~ 1 1/8" thread length / Obsolete.
Fits: 1973/79 F100/350 2WD.
Many of these bolts have been replaced, some more than once. So the bolts that are there now, may not be the originals.
btw: For y'all that recognize FoMoCo part numbers, and wonder what this number in blue is. It's a standard (hardware) part number.
Internet search for NOS (new old stock) originals:
Don Sanderson Ford in Glendale AZ has 8 = 623-842-8762
Andersen Ford Sales in Bellfontaine OH has 2 = 937-592-6010.
That's it. No other Ford dealer, or obsolete parts seller has any.
I really do appreciate all the information from everyone.
Sanderson would prolly prefer to have none because they cannot be returned to Ford.
Call 'em up and ask, I provided their phone number.
Thanks. :)
My steering gear is threaded.
My 7/16" bolts never got loose, I put a jam-nut on the them way back when tho. :)
Just didn't like the looks of them naked bolts holding my steering gear on is all.
Over time the bolt heads sucked into the soft frame steel. So then added
some super-extra-thick dished-spring-like washers under the bolt heads,
I found 'em in a wrecking yard.
Still don't know what they were originally for.
Intake/exhaust manifold washers?
In this case there was a problem with the softass frame steel.
Otherwise washers etc just add to the problems. :/
I was a railroad signal maintainer and so maintained power switch machines
and the switch points that go with them.
If you want a bolt and nut to stay put...
Leave off all the washers and other junk it doesn't absolutely need.
They are just sources of play.
Split-ring lock washers are the worst thing they ever came up with.
Leave those off for sure. :/
Double nut the bolt.
Gov't required a cotter pin. :)
That sucker was great for not letting the nut fall all the way off! :)
But in a half a month the nut rattling around on the bolt would ruin both
the bolt and the nut. ...didn't fall off but did nothing to keep the nut tight.
Some of the bolts need the track department to help change them out.
I fiNgured out all on my own that... if I took all the washers off and double
nutted the bolts... those bolts and nuts would out-last the switch points! :)
Funny thing was, no one was interested in the information. :(
No overtime to be had... in things that don't fail.
Works on a trailer ball too.
"Cotter pin" will keep it from falling off but
"no washers and double nutted" will keep it tight.
Take your pick. ;)
Use a real wrench tho, not a springy "Cresent" wrench and a piece of pipe.
BTDT! ;)
Alvin in AZ
