1992 Explorer window regulator
Old Oct 1, 2008 | 01:45 PM
LA2AK's Avatar
LA2AK
My windows are not operating anymore. They can only be opened and closed by the driver. My passenger window sometimes won't go up it does not happen often but I am afraid it won't go up one of these cold days. Is my motor out if I can still open and close the windows? How hard is to change the motor? Is there anyplace on the web that will give me instructions?
Thank you.
Old Oct 1, 2008 | 04:50 PM
Franklin2's Avatar
Franklin2
If the motor still works with one switch, then I would suspect the other switches. Sometimes what you can do is wiggle all the switches back and forth, and then go around and see if any of them take off and work the window.
Old Oct 1, 2008 | 05:47 PM
LA2AK's Avatar
LA2AK
1997 Explorer window problem
Will I have to remove my door panel to find any loose connections so that all the windows will work? They all work from the driver side but not individually.
Old Oct 1, 2008 | 05:51 PM
subford's Avatar
subford
Do you have a 1992 or 1997?
Old Oct 1, 2008 | 08:28 PM
jimdandy's Avatar
jimdandy
Ford window problems, especially on older trucks, are usually mechanical not electrical. The gears are white plastic, and disintegrate over time. This causes the windows to get stuck, occasionally not go in one direction, etc.
If you can hear the relay click, or hear the motor try to work, the problem is mechanical.
You should be able to get a gear kit from your local auto parts as this is a common problem. Remove the motor/gear assembly, open the gearbox for inspection.
The assembly is held in the door by 3 screws, 8mm if I remember correctly. Two of the screws are exposed, and one is behind the panel. There is a dimple in the panel in relation to the two exposed screws to indicate where the 3rd screw should be. Drill the dimple, and you will see the 3rd screw. Prop the glass up out of the way, and remove the assembly.jd
websthes
Jan 25, 2008 04:02 PM
jason86
1978 - 1996 Big Bronco
Feb 8, 2005 02:58 PM
baw289
Jan 29, 2004 04:15 PM
devilstrip
Dec 31, 2003 12:18 PM
shotgunner426
Oct 3, 2003 04:06 PM
