manual driver door window won't open/close
my driver side door window won't open or close. i finally got round to taking the door trim off. seems the glass fell off the arm that lifts it up. i can lift the glass up by hand and wedge the arm back under the glass and when i crank it will close the window. But when i crank to open the window, the arm slips off the glass causing the window to fall back down.
it's a 93 regular cab f150, power nothing
Originally Posted by Conanski
The regulator arm should have a plastic piece on the end that slides into the track on the bottom of the window glass, either this piece is missing or damaged I would suspect.
yeah there's a wobbly bit of square plastic on the end of the regulator arm... it works fine to raise the glass but when i roll it down the arm goes down before the glasss and then slips off.
I have close to the same problem. When I roll down either window, it wants to stick. I have to push down on the glass to get it to go down while cranking. Going up is fine. When the truck is warm or in the sun, I notice it goes down easier. I figure the glass is falling out of the track but I just haven't had the time to pull the door apart. No idea what is in there
Ok really need some help here guys. I sprayed graphite jiggy loo in the window tracks and it slides a little better but when I go to crank the window down the lever will go down, but if the window doesnt slide down fast enough to stay resting on the lever, it slips off.
I bent the lever a bit so it stays drop centre under the glass and the glass doesn't fall down in the door when the lever slips off but I still need to figure out how to force the glass down.
there's some rubber trim on the bottom of the glass that's peeling off but I can't see anything that looks like it's designed to force the glass down.
the only Idea i can come up with is to duct tape a thread of re-bar wire along hte bottom of the glass and fasten that to the crank so it actually pulls the glass down.
Window Roller 1973/96 F100/350/Super Duty/Bronco/Econoline/Passenger Cars
The plastic window roller has broken.
The window roller is a squarish piece of plastic (actually nylon) with a threaded metal pivoting stud on one end, that is pressed into the plastic roller.
The stud bolts to the end of the window regulator arm (with or without P/W's), the roller portion slides into the window channel that's bolted to the door glass.
What happens > > The threaded stud pulls out of the plastic roller.
Result = the window falls into the door.
Plastic window roller D6AZ-5323240-A = Fits ALL 1973/96 F100/350's, Bronco's, Econolines, and most 1973/2008 passenger cars. Super Duty's from 1986.
(Ranger/Bronco II/Explorer...features a slight design change, so a different part number is used: E9TZ-1023240-A).
Available from Ford, and autoparts stores nationwide.
Ford suggested retail price: $7.88
Zackery Ford
02-04-2017 03:48 PM
v860rich
10-06-2016 04:31 PM
BandVan
07-14-2012 04:31 AM
