Bed floor progress
Old Sep 30, 2008 | 12:23 PM
tip49's Avatar
tip49
Bed floor progress
I stained bedwood this weekend; used thinned black paint and will rub-in boiled linseed oil to hopefully give me a weatherproof finish. Boards are blacker than picture would indicate.
Old Sep 30, 2008 | 03:46 PM
fking1's Avatar
fking1
Y not use clear urethane varnish?
Old Sep 30, 2008 | 04:10 PM
tip49's Avatar
tip49
Varnish
I've never found a varnish that did not require sanding and re-application every couple years, including marine spar varnish. I've used oil on furniture; thought it might stand up better.
Old Sep 30, 2008 | 04:12 PM
fking1's Avatar
fking1
I've had marine urethane varnish on my bed wood for over 25 years and have never touched it except to wax.
Old Sep 30, 2008 | 04:21 PM
tip49's Avatar
tip49
Marine Varnish
That is good result; does your truck see much wet weather. I don't want to have to mess with re-varnishing every 2-3 years.
My only experience with the spar varnish was on woodwork on boat, as well as lawn furniture.
Tom
Old Oct 1, 2008 | 09:39 AM
MAR-Ktech's Avatar
MAR-Ktech
Former Vendor
If you are interested in the longevity of different bed wood finishes, you might want to check out our website. We have done 2 different finish tests in the last few years and have all this information available online. See the following links:
Wood Finish Testing - Testing of different wood finish products
We also have suggestions on how to finish bed wood:
Wood finishing suggestions
Hope these help!
Old Oct 1, 2008 | 10:03 AM
Jag Red 54's Avatar
Jag Red 54
I used spar varnish with good results. But I don't use mine in the rain. This paint/oil method may be another route for those that want a "working finish". It seems like it would be a lot easier and less expensive. Please let us know on your progress after a few months of rain. Jag
Old Oct 1, 2008 | 11:44 AM
fking1's Avatar
fking1
Tom
Never sees rain and a summer only cruiser.
Old Oct 1, 2008 | 05:17 PM
Jon T's Avatar
Jon T
Thanks for posting your test results on the multiple finishes, I am in your debt!
Jon
Old Oct 1, 2008 | 05:21 PM
John - NNY's Avatar
John - NNY
It is always good to see progress.
John
NNY
Old Oct 1, 2008 | 07:57 PM
grumpy46's Avatar
grumpy46
mar-ktech. i want to add color to my varnish or urethane can i use paint or do i need an additive.
tom
Old Oct 2, 2008 | 08:40 AM
birdman1's Avatar
birdman1
Bed boards look good. I know what you mean about the varnish breaking down and needing attention. I used the best Spar varnish I could find on porch rockers that sit on a covered porch on my shop but the varnish cracks and peels off. Like others have said, it depends on where the truck will be stored.If it's in a garage and only driven on pretty days the varnish will last a long time.but if it is sitting outside (like mine is for now)then the spar will surely break down.
Later, Mike
propellerhead
15
Apr 25, 2017 12:28 PM
Raleigh1
1978 - 1996 Big Bronco
682
Mar 18, 2016 01:29 PM
DaXman
Jul 3, 2015 05:38 PM
postoak99
1997 - 2003 F150
Mar 5, 2011 11:05 AM
