I stained bedwood this weekend; used thinned black paint and will rub-in boiled linseed oil to hopefully give me a weatherproof finish. Boards are blacker than picture would indicate.
I've never found a varnish that did not require sanding and re-application every couple years, including marine spar varnish. I've used oil on furniture; thought it might stand up better.
I used spar varnish with good results. But I don't use mine in the rain. This paint/oil method may be another route for those that want a "working finish". It seems like it would be a lot easier and less expensive. Please let us know on your progress after a few months of rain. Jag
Bed boards look good. I know what you mean about the varnish breaking down and needing attention. I used the best Spar varnish I could find on porch rockers that sit on a covered porch on my shop but the varnish cracks and peels off. Like others have said, it depends on where the truck will be stored.If it's in a garage and only driven on pretty days the varnish will last a long time.but if it is sitting outside (like mine is for now)then the spar will surely break down.
Later, Mike
