Drivers side headlight dim
Old Sep 28, 2008 | 03:41 PM
Fordman_Evs's Avatar
Fordman_Evs
Afternoon fellas,
The other night I noticed that my drivers side headlight is much dimmer then the passengers side. When I switch to highbeams it gets brighter but it is still much dimmer. I checked the connections they are both tight and the lens are fairly clean, and both bulbs are fairly new. Any ideas?
Cheers,
Evs
Old Sep 28, 2008 | 08:58 PM
tbear's Avatar
tbear
Swap the bulbs and see if the problem persists. If so, it's probably an electrical connection. Either corroded pin or short draining power.....
Old Sep 29, 2008 | 12:11 AM
preppypyro's Avatar
preppypyro
You said the lens's are clean, but is the one faded at all?
I would check the connections also, clean em if they look questionable.
zhilton
May 28, 2011 02:31 AM
AmericanMade
Aug 28, 2010 09:54 AM
steve55
1997 - 2003 F150
Mar 25, 2010 08:59 AM
Billyclub
Apr 8, 2009 04:13 PM
bigboi96
2004 - 2008 F150
Feb 18, 2009 11:04 AM
