Sponsored by: Auxito
headlight dimmer switch
Old Mar 24, 2010 | 10:54 PM
steve55's Avatar
steve55
I have a 97 F150 and would like to install a floor mounted headlight dimmer switch. Has anyone done this? My MFS keep shorting my drivers side headlight.
Thanks
Steve G
Old Mar 25, 2010 | 02:18 AM
Bluegrass 7's Avatar
Bluegrass 7
Why not replace the stock switch and avoid the wiring hassle.
It's a plug up deal once you get acess to the column.
Old Mar 25, 2010 | 08:59 AM
Ron W.'s Avatar
Ron W.
I'm with bluegrass7 change your multi-function switch, very easy to do and probably no more espensive than buying the needed components and wireing to set up a seperate switch. And be darn sure you inspect BOTH sides of the electrical connectors for discoloration / heat, it might be one of the connectors causing the problem.
Tilleyman
Feb 12, 2016 05:48 PM
mustangpt
Apr 22, 2015 09:59 PM
johna2u
Electrical Systems/Wiring
Dec 18, 2006 08:41 PM
kenpep2
Sep 28, 2003 07:37 PM
g-a-w-d
Aug 27, 2003 07:14 AM
