Isspro EV2 Installation
Old May 27, 2011 | 05:41 PM
zhilton's Avatar
zhilton
I'm getting ready to install a set of Isspro EV2 gauges in my truck. I picked them up through RiffRaff (great service by the way). When he shipped them to me, he through in a dimmer switch & extra wiring harness for the gauge lights. Do I need to dim the EV2 gauge lights? I run my OEM gauges on full bright and only touch the dimmer **** to turn on all the interior lights/cargo lamp.
Old May 27, 2011 | 06:54 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Yes, I would because the LED backlighting will be much brighter than on your dash.
Old May 27, 2011 | 07:37 PM
Mulepick's Avatar
Mulepick
I installed mine in 09 so memory is a little fuzzy but the wiring instructions I followed automatically had them controlled by the OEM dimmer.
Old May 27, 2011 | 08:36 PM
dchamberlain's Avatar
dchamberlain
I wired my light wire directly into the existing illumination wire and I don't see that the gauge is too bright. I would do that first and if it is too bright, then you can disconnect it and put in an additional dimmer resistor.
Old May 27, 2011 | 09:03 PM
zhilton's Avatar
zhilton
That's what I was wondering. I don't have the truck handy right now to compare lighting between the two or I would have toyed with that for a bit first.
Sounds like I might be better off test wiring one or two of them in and seeing how I like them at full power before I button everything up. Thank you for the information gentlemen.
Now if the truck was only here so I could get on with this project.
Old May 27, 2011 | 10:24 PM
BLADE35's Avatar
BLADE35
my brother in law has them mounted on the pillar and he wishes he could just dim them and not the whole dash
I guess it kinda blinding at night making a left hand turn
Just something to think about if your mounting them on the pillar
clay do you sell just the dimmer I think thats all he needs I will send him your way thanks
Old May 28, 2011 | 02:31 AM
Riffraff Diesel
PREMIUM SPONSOR
Here is a link for you.
Riffraff Diesel: Potentiometer Lighting Wire Harness
white Buffalo
Mar 5, 2014 11:02 PM
90pioneer
Apr 20, 2013 05:31 PM
Km1210
Mar 27, 2012 02:55 PM
AmericanMade
Aug 28, 2010 09:54 AM
deadeye01
31
Jul 27, 2010 12:28 PM
