Won't start unless in Neutral
Old Sep 27, 2008 | 03:34 PM
Gergs's Avatar
Gergs
Hi all.
94 F150 5.0, 183,000 miles.
Have been having problems lately, won't actually go into Park at all...really only into Reverse....everything is one "off", you know? So since I can't get it into park, I have to shift to Neutral to start it.
What is wrong here? And, yes, I have to always put the parking brake on when leaving her because she's not really in park.
This is getting old and getting worse. How do I fix this?
Thanks,
~gergs
Old Sep 27, 2008 | 05:10 PM
Redcat Diesel's Avatar
Redcat Diesel
Hi Gergs, here's something you might want to try. Under the hood look at the base of the steering column where it comes out of the firewall. You will see where the shift cable connects to the column. Disconnect the cable at this point then check to see if the shift lever works as it should. If it does the problem is in the cable or trans. If it still doesn't shift correctly the problem is in the column. To isolate the cable disconnect both ends and see if it moves freely in it's housing. If it binds the cable is breaking apart inside and needs replaced.
A couple notes here. First I'm pretty sure 94 trucks used a shift cable but it may have linkage. Troubleshooting proceedure is the same. Second if you have a column problem and decide to fix it yourself you might want to borrow or buy a service manual that covers it. Big thing here is the air bag. My 96 has one but I'm not sure if the 94 trucks had them. I'm told accidentally inflating the bag while working on the column is both painful and expensive.
Old Sep 28, 2008 | 12:21 AM
GrimOne's Avatar
GrimOne
My 1996 did the exact same thing, my problem was in the shift tube (which is in the column) 2 bushings that go bad on the rod itself, and you also have a connector on the very back of the shift tube where the cable attaches that can come loose as well which can be tightened up with a torx bit (I forget the size I used) not sure how much help I am, but it's what worked for me. This might be of some help, it's basic visual on the bushings in the column another on the forum might be able to better identify the other issue (connector on the back of the shift rod)
1996 Ford C-150 (Centurion Conversions) Fixed Loose Shifter pictures, videos, and sounds | SuperMotors.net
Old Sep 28, 2008 | 04:20 AM
metmag52's Avatar
metmag52
As for the air bags ( if it has them) just disconnect the battery and wait a couple minutes for power to delete--no problem if there is no power--
Gary
willeo6709
Nov 28, 2011 11:34 PM
iron1951
Feb 18, 2011 06:39 PM
427 fordman
Sep 21, 2009 07:44 AM
nosagroy
Apr 3, 2009 07:47 PM
David26
Aerostar
May 24, 2004 10:42 PM
