loose shifter on column
Old Sep 16, 2009 | 06:48 PM
427 fordman's Avatar
427 fordman
My shifter is quite loose on the column and sometimes it won't start in park. Sometimes I have to push it up further to work. Once in a while it won't start in park no matter what I do. If I put it in neutral it will start then. Is there a wore out bushing or something in there affecting my neutral saftey or what?
Thanks guys
Old Sep 16, 2009 | 06:51 PM
maverick1701's Avatar
maverick1701
Thanks guys
the shifter wire will stretch over time but IIRC there are some screws you can tighten in the steering column...some of the gurus will probably chime in here in a min
Old Sep 16, 2009 | 07:00 PM
brooksbronco17's Avatar
brooksbronco17
maverick is right, two i think 10mm bolts on the end of the shifter that you can see under the dash while lying on the floorboard. Look up with a flashlight and have someone wiggle the shifter. You'll see it right off. Tighten and your golden
Old Sep 16, 2009 | 07:22 PM
427 fordman
Sweet. Thanks guys, I'll look at it this weekend when I'm at the shop.
Old Sep 16, 2009 | 07:44 PM
redone1's Avatar
redone1
yep definately two screw there under the dash. mine were loose a ways back. Think they are philips head.
Old Sep 16, 2009 | 09:47 PM
strokin'_tatsch's Avatar
strokin'_tatsch
either that or there are 2 plastic bushings in the steering column that can go bad too. i'm sure the others no better than i do though. i know there are bushings but i would try the tightening first. i'm a 5 speed guy so i don't know anything about autos... LoL
Old Sep 16, 2009 | 11:11 PM
joe_13894's Avatar
joe_13894
IIRC they were torx. If you're doing any dash work, you need to invest in a torx set.
Old Sep 17, 2009 | 08:30 AM
Action4478's Avatar
Action4478
Look Here ....
Old Sep 19, 2009 | 03:39 PM
427 fordman
Thanks for all the help again guys. Holy crap, I looked under there and one was almost completely out and the other was backed out 1/4 inch or so. I feel like a dumba$$ not looking under there before. I always had a hard time getting into reverse. It would go past to neutral a lot. Tighten two bolts and good to go. I can even notice all my detents good now. That arm was just slopping all over under there.
Again, thanks for the easy fix. Wish they were all like that.
Old Sep 19, 2009 | 06:04 PM
etldak's Avatar
etldak
Mine needs the bushing when ever i can find them
Old Sep 21, 2009 | 07:44 AM
redone1's Avatar
redone1
Glad to hear your good to go now. Mine was so bad once that it slipped into reverse from park. i bairly nudged it with my arm. Scared the heck out of me when it did it!
84red
Jul 8, 2017 02:29 PM
Action410
Jan 18, 2013 07:40 PM
Fox Fader
1997 - 2003 F150
Mar 1, 2011 03:00 PM
iron1951
Feb 18, 2011 06:39 PM
Slopitch
Sep 13, 2008 12:36 PM
