Help Still Have E40d Problems
Old Oct 7, 2008 | 06:56 PM
  #31
GenLightening's Avatar
GenLightening
If you need any help, I do have a friend there who's a pretty good wrench. Should I check with him before loaning him out? LOL
Old Oct 7, 2008 | 07:04 PM
  #32
JOHN CHAPPELL's Avatar
JOHN CHAPPELL
At this point I'll take all the help I can get. I'm not bad though this small stuff just can't figure out now big yellow and loud that's my style.
Old Oct 7, 2008 | 10:44 PM
  #33
ford trans tech's Avatar
ford trans tech
if the trans has 1-2-3 gears it is not a solenoid
in the E4OD there are only two shift solenoids if one is bad it will affect two different gears not just one
have you checked for codes
beyond that assuming the pcm is commanding 4 th gear then it would be either a shift valve in the main valve body or the overdrive clutch control valve in the accumulator body is stuck open
Old Oct 7, 2008 | 10:55 PM
  #34
ford trans tech
have you driven it and checked the engine rpm at a given road speed and then disconnected the trans connector and repeat the test
Eric
Dec 25, 2018 02:13 PM
mxjmz1997
Jan 20, 2011 11:05 AM
qman4467
1983 - 2012 Ranger & B-Series
Mar 29, 2010 09:03 PM
pchristman
Jan 6, 2004 10:55 AM
