Help Still Have E40d Problems
Old Sep 25, 2008 | 12:54 PM
JOHN CHAPPELL's Avatar
JOHN CHAPPELL
WELL I'M BACK AND STILL HAVEING TRANNY PROBLEMS THIS TIME TRANS SHOP SAYS TRANS IS FINE BUT STILL WON'T SHIFT RIGHT TRANS SEEMS TO SHIFT FROM 1ST TO 3RD AND NO OVER DRIVE WITH NO FLASHING LIGHT ON THE OVERDRIVE SWITCH. HAVE REPLACED THE FIPL SWITCH AND SET REPLACED THE MANUAL SELECTOR SWITCH WAS WONDERING IF THE TRANS CONTROLLER COULD BE THE PROBLEM? TRANS SHOWS NO CODES. HELP PLEASE THE TRUCK IS A 93 CREWCAB 2WHEEL DUALY
Old Sep 25, 2008 | 04:26 PM
FORD MEGA CAB!!!'s Avatar
FORD MEGA CAB!!!
It sounds like the TCM has no power or is dead. Will your overdrive off light even come on if you press the o/d off button? First check all your fuses. After that, I really don't know where to go from here cause I have never had this problem (yet). You can unplug the tranny from the tcm and if it shifts the same, then you know its a tcm issue, possibly power to it, or electrical between tcm and tranny.
Old Sep 25, 2008 | 04:36 PM
JOHN CHAPPELL
The Over Drive Light Seems To Function Right Turns On Off But Trans Doesn't Change Also Replaced The Engine Speed Sensor.
Old Sep 25, 2008 | 07:31 PM
David85's Avatar
David85
Very strange that no codes would be thrown.
Does manual second gear work?
Old Sep 26, 2008 | 11:25 AM
JOHN CHAPPELL
well I just did the check that david85 said trans shifts good 1,2,3 manual still no 4th and still no codes no flashing light or on the scan tool
Old Sep 26, 2008 | 05:09 PM
LilDuke's Avatar
LilDuke
Try shifting manually with the od off. when you get to third, then turn it on. You should feel 4 distinct shifts. Above 37mph you should also get torque converter lockup, which if working right will also feel like another shift. I suspect maybe the tc may be at fault if the tcm is working properly. Does reverse function normally?
Old Sep 27, 2008 | 02:05 PM
JOHN CHAPPELL
shift dosen't change whether light is on or off manually when I shift manual it shifts solid and reverse is solid just no 4th gear or if you select drive then that is when it shifts 1st, 3rd skips second and very weak shift like converter slip and no 4th gear.
Old Sep 27, 2008 | 06:46 PM
Franklin2's Avatar
Franklin2
If the computer will not talk to you at all, then I would concentrate in that area.
Old Sep 27, 2008 | 07:23 PM
GenLightening's Avatar
GenLightening
I have the computer out of my '90 and, if it's the same, you can try it to see if anything changes. It's currently on loan to a member in WV and I think he's done with it, I can have him send it down to you.
Old Sep 27, 2008 | 08:01 PM
EMD_DRIVER's Avatar
EMD_DRIVER
I'd be happy to! Just let me know where!
Gary
Old Sep 28, 2008 | 07:49 PM
JOHN CHAPPELL
Does any buddy know what year the trans controller covers and are they the same for the gas rigs with the E40D or is the IDI all it's own.
Old Sep 28, 2008 | 08:14 PM
David85's Avatar
David85
The controller is specific for that era of diesel E4OD transmissions. Years from 1989-1993 are all IDIs.
Old Sep 28, 2008 | 08:17 PM
JOHN CHAPPELL
thanks so I have to find a 93 controller?
Old Sep 28, 2008 | 08:22 PM
GenLightening
No, sounds like they're all the same for the IDI. Get your address to EMD_Driver and then see if it takes care of the problem.
Old Sep 28, 2008 | 08:37 PM
JOHN CHAPPELL
thanks guys I really appeciate the help getting very discoraged
