6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
black soot...
Old Sep 21, 2008 | 07:44 PM
  #46
rob_nc's Avatar
rob_nc
Originally Posted by cHiLi 11
Can anyone else chime in where there DPF was cracked. Again, my tips are black and the tech says he does not see any visble cracks. I would like to try and be able to show him a specific spot if possible. He still seems to think the tips being black are from a defective EGR valve.
Nick
The DPF doesn't crack on the outside. It has to be removed and looked at thru the inlet and outlet. If the outlet of the dpf is black with soot, it is cracked. Even though a DPF's efficiency is only 90+%, it will remove the larger particles first. It's efficiency also increases as it collects soot.
Old Sep 21, 2008 | 08:13 PM
  #47
Lead Head's Avatar
Lead Head
Even if the EGR is stuck open, the DPF would still have to capture the excessive soot the engine would be creating. Like it was said, DPFs crack internally, they are not visible on the outside.
Old Sep 22, 2008 | 07:03 AM
  #48
rob_nc's Avatar
rob_nc
It's the excessive soot that is cracking the filter. A regen on an overloaded filter causes localized super-hot spots in the ceramic substrate. This is what cracks the filter. I've cracked more than one filter from something as simple as a malfunctioning egr mass flow sensor. I've also cracked a filter due to a cracked CAC.
Old Nov 20, 2008 | 08:01 PM
  #49
livinlarge4u's Avatar
livinlarge4u
Originally Posted by EricHB
hello people-
i own a 6.4 with about 1800 miles on it. i noticed that the tail pipes are pitch black so i took it to my local dealer today. showed the service adviser and he said thats perfectly normal. i told him he didnt know what he was talking about and asked for a tech to look at it. tech looks at it and asked me if its ever gone ino regen and i told him it has...once. he said that the black soot is from the truck going into regen and that i should reflash it for the latest program.
is this accurate? doesnt black soot usually mean a cracked dpf? any advice on what i should do? thanks!
hey eric this is livinlarge4u it mean you have lost a injector in your truck go to the dealer and tell them to run a injector test
Old Nov 20, 2008 | 08:05 PM
  #50
livinlarge4u
eric my friends have had problem with the injectors going bad
Old Nov 21, 2008 | 01:43 AM
  #51
EricHB's Avatar
EricHB
wouldn't a failed injector throw a cell?
F stock owner
6.7L Power Stroke Diesel
Jan 20, 2014 12:26 AM
milsuper
Mar 17, 2012 01:40 PM
Chief Engineer
Dec 19, 2011 06:22 AM
dwilliamsceg
38
Jul 3, 2011 10:13 PM
goneon66
54
Jul 29, 2008 10:12 PM
