Good news, then bad news, then worse news - Re: Clogged DPF and leaking radiator
2008 Job 1 Manual tranny - 60000 miles
I am starting a new thread to discuss my recent issues with regens. In summary, every 20miles the truck was going into regen and staying in for a long time.
I took the truck to Phil Long Motor City yesterday. They looked at it and scanned the computer and ran a PSI test on the exhaust. They said that the DPF was clogged because, as the computer showed, I kept shutting it off in the middle of regens. I explained that this started on a trip west to CO from VA about halfway and I went over a thousand miles when this started. They said that the repeated shut offs during regen eventually clogged the DPF and all but pointed the finger directly at my driving style. I asked what I should do when it takes the thing 40 miles to regen.
Anyways, they forced a manual regen, said the DPF was cleared out, and everything was okay. They also found a very small leak on the drivers side of the rail frame where coolant was leaking out. They quote me $1300 to fix it I told them that I would figure something else out.
So, on my drive home back to Woodland Park, I got about 15 miles from teh dealership when she goes into regen. I call my service manager, Clayton, and he says to watch it when it comes out. I asked him how many miles I should keep driving and he said that if it is over 10 or so, to bring it back in. Instead oh heading home, I took 67 North to Deckers and it took 30 miles for the regen process to stop. I recorded all of this on my blackberry, called Clayton and he said to bring it back in immediatley (tomorrow).
So, here's where I stand - My truck is in regen more than half the time and whatevery they did to it did not work. Plus, now I find that my radiator is leaking and, according to Clayton, it is a complex job to replace it on my own,.
I really want to ditch the damned DPF but I don't want to void the warranty.
I am taking the truck back tomorrow. Is there anything that I should bring up with them?
BTW - overall, Clayton and the folks there have been very friendly and helpful. I asked him a ton of questions and he even crawled under the truck with me to show me the leak.
Dave.
Dave.
They need to go further with the DPF issue. Check the turbos to see if they are leaking, check injectors to see if they are leaking as well.
Probably need to check the DOC as well.
As for the radiator issue, they need to test EOT/ECT split to see if you have hyperextended or sticking thermostats. If so then radiator will be covered because the true cause is thermostats.
Also suggest a pressure test to check the EGR coolers. If there is an issue there that could possible effect the DPF.
What do your tail pipes look like? Any moisture?
as Scott says they need to investigate more.. here is another tale of trouble from insufficient diagnostics
and ps.. it is NOT YOU.. or your driving..
https://www.ford-trucks.com/forums/9...ml#post9311236
DPF is in regen cause something ELSE is causing it to fill up.
there is a TSB (Tech Service Bulletin) on how to test the pressure for the rads to determine if the thermostats are at fault.
Sam
Sam
Sam
Sam
They seem genuinely desirous to help. I will drop it off tomorrow, ask some of the questions posted here and see what happens. I am ready to drop the DPF off alltogether but am concerned that it may be another issue causing the regens.
at SOME point you have to drive to clean it.. and it should display a message.. 'drive to clean exhaust system' I've seen it once in a year.
and it MIGHT take 20 miles. never had mine go longer than 20.
here is the link to the rad tsb info
https://www.ford-trucks.com/forums/9...ml#post8341110
on the cleaning here is the op manual text
DRIVE TO CLEAN EXHAUST SYSTEM (Diesel engine only).
Displayed when the engine control module detects the Diesel particulate filter (DPF) is full of particulates and that the vehicle is not being operated in a manner to allow automatic cleaning. The vehicle operator has to drive the vehicle above 30 mph (48 km/h) for at least 20 minutes to clean the DPF. This will continue to be displayed until an adequate drive cycle is completed. This message is NORMAL.
Well, just reviewed the owners manual suppliments. Does not really say.
But 10-15 miles to me would be a normal event.
Just a thought, if you have fuel reciepts you may want to round them up and have them on hand. Be able to prove that you are using ULSD vs LSD or bio-fuels.
Could they try and blame this on bad/incorrect fuel?
Two weeks ago I left Tucson. heading towards Minnesota. The first day across Arizona and New Mexico my 450 started to regen often, mine happens to have the 4.88 rear end. I was getting 30 miles between regen, with the regens taking 15 to 20 miles to clear. The temp outside was 100+ degrees, I had a slight head wind and was driving 65 to 70 mph pulling a 39 ft 5th wheel. We spent the night in Las Vegas New Mexico and the next morning the temp was in the high 50tys and our first regen came at 157 miles. I have never had that towing it's usually about 100 miles and the rest of the day was normal. I also saw some thing else that morning from L.V. into Colorado I got 13 mpg on my first tank. I slowed down that day and tried to stay at 60mph had cooler temps, had the wind behind me and it was down hill a lot. Do your traveling condition compare to this? My truck seems to be acting normal now.
