Offroad & 4x4
4x4 Not Engaging
Old Jan 6, 2003 | 08:45 AM
DJBigDog's Avatar
DJBigDog
4x4 Not Engaging
I have been told that they motor on the transfer case is notorious for going bad. I am going to do some checking into that next weekend.
I will let you know.
JM
Old Jan 6, 2003 | 11:04 PM
steve83's Avatar
steve83
4x4 Not Engaging
strengthtrusthonor
Your problem sounds like the vacuum actuator on the front axle. You have no locking hubs and the fact that you CAN go to low range says your t-case shift motor (not a floor lever) is working.
Old Jan 7, 2003 | 07:10 AM
strengthtrusthonor's Avatar
strengthtrusthonor
Post 4x4 Not Engaging
Thanks, Steve... the vacuum actuator. Do you have a schematic/picture of where this is located and how to test it? Replacing/repairing this would take less time than draining the t-case... again thanks.
Old Jan 7, 2003 | 08:04 PM
Bronco408w's Avatar
Bronco408w
4x4 Not Engaging
My four wheel drive just won't engage. The t-case seems fine. And the vacuum actuator on the axles seems fine; tested it with a hand vacuum pump.
Lately (since we have gotten snow), I have been trying the 4x4. It seems that it will engage but is slow. I put a gauge on the the on the vacuum line to the solenoids. It only read a couple of inches of Hg. My latest theory is that this is not enough vacuum to operate the actuator. Next time I have a chance, I will connect to a stronger vacuum source (if I can find one) to see what happens. Maybe there is a cracked line somewhere.
strengthtrusthonor,
Yours sounds like a mechanical problem. The t-case in my 74 Bronco would pop out when under power. Installed a rebuilt one and the trouble stopped.
The vacuum actuator is on the top of the axle under a plastic cover. The solenoids that control in are on the fire wall, far passenger side.
Old Jan 7, 2003 | 09:51 PM
steve83's Avatar
steve83
4x4 Not Engaging
I'm not familiar enough with '97-up trucks to give you any specifics, but I'd ALWAYS advise getting the Haynes manual. I'm sure it's in there.
Old Jan 9, 2003 | 03:06 PM
WXboy's Avatar
WXboy
4x4 Not Engaging
Yeah, sounds like the little engage-motor in your front differential is dead. This happened to me on my Z71 pickup years ago...it went out during a snowstorm. (Damn GM junk). But anyway, GM replaced the little factory gas-operated motor with an electric one. It just slid right into a hole and screwed in where the front diff. is. Then you just connect the wiring harness and you are ready to go. I think the one for my truck then was like 60 bucks or something. It's a job that could be done in 30 minutes or less on a GM truck...so I am assuming it should take less time on a well-engineered Ford :-X12
Good luck.
Old Jan 9, 2003 | 06:14 PM
steve83's Avatar
steve83
4x4 Not Engaging
The OE GM actuator is an oil-filled cylinder with a little heating coil inside. When power is sent thru the coil, the oil expands & pushes a piston that engages the axle. Of course, if it's cold outside or if you drive in snow, you lose 4WD. :-X23 You can find MANY aftermarket fixes, including vacuum, cable, and solenoid actuators.
GM
Old Jan 10, 2003 | 08:14 AM
strengthtrusthonor
Does anyone have a schematic/drawing/photograph of these components on the truck? (solenoid, vacuum motor, etc..)
Old Jan 12, 2003 | 07:48 PM
steve83's Avatar
steve83
4x4 Not Engaging
You can almost certainly get a CD for your truck (and all other trucks & vans of that year) off eBay for under $10. I have 3 and to me, they're worth about $20ea after shipping, so that's how I'd recommend you bid.
Old Jan 14, 2003 | 09:05 AM
strengthtrusthonor
4x4 Not Engaging
Okay, let me get all this straight. After reading through all of the postings, I'm seeing several different ideas.
Considering that I have a 1997 F-150, the low gear engages fine, but the 4x4 seems to 'pop' out under high torque or sharp turn, does the group feel that the problem is:
1.) In the vacuum motor/lines
2.) In the transfer case/center connect/disconnect
3.) In the floor-mounted shift lever
I bought the CD for f-150 troubleshooting and it's on the way. Still, I'd like your opinion/expertise. Thanks...
PS. I've learned alot from you guys (about locking hubs, etc.) so I'm really thankful for the website. All except for those little annoying faces over there on the left. Here, I'll use my first one ever: (What the heck is he doing?)
Old Jan 14, 2003 | 08:03 PM
kspilkinton's Avatar
kspilkinton
4x4 Not Engaging
I'd say it's whatever holds that shift fork in place and the shifter's engagement, probably just an adjustment as it engages sometimes, also make sure you jam that shifter home as the 4H position is al the way against the stop for neutral. You apply torque and it wants to shift out... so the 4L is being held in by the oddball zig-zag in the shift pattern.
-Kerry
That little guy is obviously enjoying himself... They emoticons are there to help aleveate the lack of face to face/in person talking. No facial expressions? then how do we know if a person is being funny or just a jerk.
Old Jan 14, 2003 | 10:42 PM
steve83's Avatar
steve83
4x4 Not Engaging
I never thought of him "enjoying himself"!
I always figured he was wringing his hands & wincing in anger at some error he just made.
Old Jan 15, 2003 | 02:49 AM
  #28
Rand's Avatar
Rand
4x4 Not Engaging
swampfire79
Jan 25, 2016 12:16 AM
scott98xlt
1997 - 2003 F150
Dec 1, 2008 04:14 PM
fordtrucklover94
1983 - 2012 Ranger & B-Series
Sep 14, 2005 08:48 PM
jbain2
16
Nov 16, 2003 12:26 PM
