Offroad & 4x4
4 Low??
Old Jan 13, 2003 | 01:20 PM
Drilim's Avatar
Drilim
4 Low??
Hey guys,
last time i was offroad, I went to put it into 4-low, and no dice. My 4x4 works, and i have never had to use the 4-low before. I was in drive, and im just wondering if it is somthing in my Transfer case, or if i need to have it in first or 2nd gear.
94 Bronco, 302, BW1356 Transfer case
Thanks
Old Jan 13, 2003 | 01:32 PM
motobub's Avatar
motobub
4 Low??
You need to have the transmission in nuetral. Then push the 4x4 lever to the left and pull up.
Hope this helps
Old Jan 13, 2003 | 09:05 PM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
4 Low??
Did the light on the dash light up or not? You should see the 4x4 light on and LOW RANGE light next to it. If LOW RANGE was not lit then you were not in 4 low. You have to stop the truck and the tranny must be in neutral. Hope this helps ya.
Old Jan 14, 2003 | 12:53 PM
Drilim's Avatar
Drilim
4 Low??
I had the Tranny in Drive. Since i have the push button on the Dash, Do i still haave to be in neutral to go into 4low? Or do i need to just be in 4x4?
thanks, Even tho this is really n00by:P :P :P
Old Jan 14, 2003 | 01:53 PM
billman's Avatar
billman
4 Low??
[updated:LAST EDITED ON 01-14-03 AT 02:55 PM (EST)]>I had the Tranny in Drive. Since i have the push button on
Need to be in 4x4 first- put in neutral, and then push 4x4 low range. Getting out of 4x4 low range- put in neutral, then push 4x4 low range.
Old Jan 15, 2003 | 02:49 AM
Rand's Avatar
Rand
4 Low??
to get to 4low you have to be in neutral
STOPPED with the foot on the brake.
to get out of 4low you have to... you guessed it.
Be in Neutral Stopped with foot on the brake.
Rand
Old Jan 15, 2003 | 02:02 PM
tw's Avatar
tw
4 Low??
Bad 674x4
Mar 4, 2013 08:17 AM
Daman858
Feb 17, 2006 04:28 AM
rml121
Aerostar
Jun 21, 2004 04:47 PM
AirSmitty
Apr 8, 2004 09:07 AM
topdogg
Mar 7, 2004 10:48 PM
