Sponsored by: Auxito
4x4 won't engage
Old Nov 26, 2008 | 11:32 AM
scott98xlt's Avatar
scott98xlt
4x4 won't engage
I have a 98 f150 4.2 5spd. transfer shift on the floor. when I try to engage the 4x4 won't go into 4H, light comes on on the dash. When shifting into 4L same thing, light comes on and transfer shifts into low but only to rear wheels. fronts not engaging in either range. slight clicking noise from under truck almost like an automatic trans when not fully engaged in park. Any ideas?
Old Nov 26, 2008 | 11:44 AM
Midnightride42's Avatar
Midnightride42
check your vacum lines to the fron. There should be two colored plastic type hoses that lead from behind the battery by the firewall to the front end. Pink and light blue I think, well mine are that color. If those are cut/leaking it will not engage your front end.
Someone correct me if I'm wrong.
Since your lights are coming on and all I wouldn't suspect anything electrical.
Also, remove your transfer case motor from the transfer case and have a buddy select the gear 2H 4H 4L and make sure the arm is actually moving in the motor to select your gear in the TC.
Hope this helps.
Old Nov 26, 2008 | 12:26 PM
scott98xlt's Avatar
scott98xlt
It seems like the gear is being selected because when in 4L it works for the rearend but the front is not engaging. thanks will look at that
Old Nov 28, 2008 | 12:33 PM
scott98xlt's Avatar
scott98xlt
checked the vac lines and they seem to be fine. took the cover off the front difff. actuator and had someone shift the TC in and out of 2H to 4H and the actuator moves but not much maybe only 3/16". Does anyone know haw much this is supposed to move? Is it possible that there might be a minor vac leak or the actuator bad?
Old Nov 29, 2008 | 08:12 AM
BATTLIN_BLAZES's Avatar
BATTLIN_BLAZES
Id put a little lube on the actuator shaft, mine was doing the same and apparently the shaft was sticking a little. been fine over two years now.
Old Nov 29, 2008 | 01:44 PM
scott98xlt's Avatar
scott98xlt
I think I got it fixed
I lubed the actuator shaft today and am able to get it into 4x4, still seams a little sticky or maybe slow is a better word, but at least I can use it now. having no 4x4 in the U.P. of Michigan kinda sux. thanks for the help.
Old Nov 30, 2008 | 08:36 AM
BATTLIN_BLAZES
use it a little bit crawl under and lude it up again, should start freeing up and get easier with time glad it worked seems to be pretty common issue with an easy cheap fix.
Old Dec 1, 2008 | 04:00 PM
Pyzon's Avatar
Pyzon
Not meaning to hijack this thread but would the same conditions apply to a '97 F150 5.4l with an auto tranny ? Lights on the dash indicate fine but no 4X4 activation ? Same location and color coding for the vacuum lines too ?
May or may not also be connected but the last time I tried 4X4 without success I found a bit (less than a couple tablespoons) of greenish fluid on the snow under the front axle, as much as it pains me to mention it.
Thanks a ton to everybody for the priceless help here.
Pyzon
Old Dec 1, 2008 | 04:14 PM
truckeradg86's Avatar
truckeradg86
the things that the vaccum lines goto 4 the 4wd goo all the time and is cheap and easy to install allmost guarantee this is your problem seeing as you still go into 4 low you know all is well... try and see what happens i pretty sure there the two boxes on the firewall and it dotmatter what kind of shift auto or stick the 4wd is vac engaged try it out and thnk me later
magyar02
1983 - 2012 Ranger & B-Series
Jul 6, 2014 01:59 PM
mattsautobody442
2004 - 2008 F150
Mar 3, 2013 09:12 AM
Katmandu
Nov 19, 2008 08:38 PM
Wild Karrde
Mar 17, 2007 07:57 AM
Wayne Hamm
Feb 15, 2005 07:07 PM
