Dip Stick tube problem
Old Aug 21, 2008 | 01:50 PM
Vin Sumerlin's Avatar
Vin Sumerlin
I recently replaced the heads on my engine, but didn't touch the block. When all was finished and the truck was running again, I changed the oil and replaced it with the required amount per the specs (actually a little over since I also have a bypass filter installed). In trying to check the oil level the dipstick is now very hard to push in , and when I do manage to get it there, no oil appears on it at . Is it possible that somehow something has gotten in the way of it, so that the end is being deflected away from the oil reservoir?
The oil pressure read normal after the new oil was added, but now reads pretty low.
I'm wondering if I have a real problem, or just an annoyance with a balky dip stick.
Old Aug 21, 2008 | 07:57 PM
LilDuke's Avatar
LilDuke
how many quarts did you put in?
Old Aug 21, 2008 | 10:26 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Vin Sumerlin,
Welcome to FTE and the IDI forum.
Is the dip stick tube still in the block?
It pulls right out.
If it is in the block, there is no place it can go except in the oil pan.
10 quarts of oil.
Old Aug 22, 2008 | 12:29 PM
Vin Sumerlin
Thanks, guys.
I poured in 3 gallon containers, plus a quart of Lucas, making 13 quarts by my math. Should have been way up on the dip stick. And, yes, the stick does go into the block, although with great difficulty. Any other ideas?
Old Aug 22, 2008 | 12:34 PM
mistakenID's Avatar
mistakenID
I'd say the tube came out and did not get back into the hole. When you put the dipstick it it's sliding down the outside of the block after working past the pan lip.
I can't think of anything internal that could get in the way like you describe.
Old Aug 22, 2008 | 01:35 PM
S.P.'s Avatar
S.P.
was the drain plug reinstalled??? (sorry I'm just being a smart @ss) I've seen it happen
Old Aug 22, 2008 | 02:03 PM
David85's Avatar
David85
I agree. I did this with mine once. If you crawl under the truck and look up with a good light, you will probably see the dipstick against the side of the oilpan. The tube can be tricky to get in.
Old Aug 22, 2008 | 03:05 PM
Vin Sumerlin
I appreciate all the advice, but I'm still stymied. I checked (again) from inside the wheel well and the tube does, indeed, enter the block in it's socket. And the stick does NOT, as far as I can tell, project out anywhere. One other clue, perhaps: when we removed the tube originally, it did not (I think) have an o-ring seal on it. Naturally we replaced it WITH an o-ring. After experiencing the problem, I unhooked the tube from the top anchor and wiggled it around to see if the stick would pop in any better---nope. No matter how much I moved the tube, the stick was stuck, as it were. I agree there shouldn't be anything interfering in the pan, but somethings not right, here.
Old Aug 22, 2008 | 09:16 PM
Dave Sponaugle
Where does your tube go when passing the exhaust manifold?
Mine is between the block and exhaust manifold between cylinders #3 and #4.
The dip stick has to be turned just right to go in, but if you hold it right it slides right in.
Any chance you pinched the tube when you reinstalled the exhaust manifold?
Old Aug 23, 2008 | 04:04 PM
LilDuke's Avatar
LilDuke
Me too, and I coulda swore I put that plug back in. Almost had the last of 5 quarts in when I felt something on my boot...
Old Aug 24, 2008 | 08:26 AM
PLC7.3's Avatar
PLC7.3
Are you trying to install the dipstic with the handle curl facing out or in........... the correct way is with the handle curl facing in to the engine.......... If the dipstick tube is not down far enough into the block the dipstic tip may be deflecting and not entering the the guide in the block and the pan.
madmax99
6.4L Power Stroke Diesel
15
Jun 14, 2009 07:25 PM
stevestroke01
Aug 11, 2008 05:18 PM
428HIGHBOY
Jul 17, 2007 10:52 PM
bloomy63
Dec 29, 2006 01:51 PM
showtime946
Sep 9, 2003 01:29 PM
