6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Oil Level ?
Old Aug 10, 2008 | 01:00 PM
stevestroke01's Avatar
stevestroke01
Oil Level ?
I just changed my oil for the first time today at 1000 miles. Every since new my oil level was up on the metal part of the dip stick every time I checked it.. I thought it was fuel dilution but today I only put in 14 quarts of oil when I refilled it and it is still reading above full. I think either 15 quarts is to much or the dip stick is reading wrong. What have you all been seeing with oil levels on the dip stick ?
<!-- / message --><!-- sig -->__________________
Old Aug 10, 2008 | 01:50 PM
Bowstring's Avatar
Bowstring
There's some post on this subject in the past if you do a search. I just changed mine for the second time and I have been staying at 14 1/2 quarts and the oil in at the top of the max. If you notice one side of the dip stick seems to have oil higher up it must set at a little angle.
Old Aug 11, 2008 | 05:18 PM
powerstrokin03's Avatar
powerstrokin03
When i change my oil ive seen anywhere from 15-16 quarts of oil. Ive been told that the trucks with DPF deletes are not making any extra oil. I put in 15 quarts at each oil change and will continue todo regardless of what comes out.
75explorerxlt
15
Feb 27, 2023 12:13 PM
40 oz
May 29, 2021 10:18 PM
mkrog
Apr 12, 2012 10:56 AM
ford2000ex
Nov 13, 2010 10:20 PM
Seabeetough
Jul 12, 2003 12:42 AM
