Offroad & 4x4
Lets help out the new guys.
Old Aug 21, 2008 | 01:03 PM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
Ok, well after reading a post stating that hockey puck body lifts were acceptable. It made me think, how fast this has gone down hill.
SO lets make a list of HORRIBLE and absolultely RETARTED ideas.
1. Hockey Puck body lifts.
Body lifts are dangerous enought, when youve got some hockey pucks with hole's drilled in them supporting the weight and loads of a truck body, bad things WILL happen. So if sliding down a hill with the chassis of your truck chasing you then shortly after runnin you over sounds like fun. Please use hockey pucks to lift your truck
2. Stacking lift blocks.
Axle wrap good enough for you? Now you want one of your blocks to fly out and kill some one, while your axle very quickly detaches it self from your truck, then running over even more people? Awesome, i suggest combining this with number 1 for even more carnage and mutilation!
thats all im gunna put for now, anybody got anything to add?
Old Aug 21, 2008 | 02:38 PM
ibleedblue1385's Avatar
ibleedblue1385
3. Coil spring spacers.
Don't do it! Quite being a cheap skate and just buy taller springs. Spring spacers are not strong and break easily. Especially when guys modify the lower coil bucket by, say, welding a piece of pipe to it, and then using a grade 5 bolt as the extension!
Old Aug 21, 2008 | 02:49 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
oh man, soooo many things come to mind, but this is just off the top of my head.....
you have already gone over this:
for love of God please dont do this:
because at the very least it WILL turn into this:
and when your done you will only have made this:
can you believe pull-a-part was asking $1200 for that steaming pile of Ford??
Old Aug 21, 2008 | 03:24 PM
Blue Bomber's Avatar
Blue Bomber
ya'll can delete this if you want, but dosnt ford use spring spacers in production trucks??
1985 Ford F-150's Avatar
1985 Ford F-150
Coil spring spreaders to lift your saggin front spring out to get it up in the air a bit or fuel line wrapped around the old radius arm bushing that wore out then holdin it all together with hose clamps.
Old Aug 21, 2008 | 03:48 PM
Truckin4life
good keep em comin!
Old Aug 21, 2008 | 04:35 PM
rbloodhound's Avatar
rbloodhound
This is some good stuff.
Old Aug 21, 2008 | 06:24 PM
suzuki1750's Avatar
suzuki1750
Dont use pressure treated 4x4 wood blocks for a body lift.
Dont use pvc or black iron gas fittings for a roll bar.
dont use rebar steel for a drag link
Old Aug 21, 2008 | 07:22 PM
Truckin4life
bwahahahahaha.... totally forgot about rebar anything..
Rebar has NO i repeat NO use anywhere on a truck... Ok i take that back, if you wanna weld a bunch of it together then to a plate as a traction aid for the bed, but other than that. NO!
Old Aug 21, 2008 | 07:33 PM
Carlene's Avatar
Carlene
Admom
Excellent thread guys.
Old Aug 21, 2008 | 07:34 PM
Truckin4life
sweetness, thanks for the props carlene.
Old Aug 21, 2008 | 07:49 PM
351slug's Avatar
351slug
Taking your date out 4 wheeling in some rough stuff thinking you cant get stuck because you have 38 Super Swampers. I never saw her again.
Old Aug 21, 2008 | 07:51 PM
ibleedblue1385
True! That would suck.
Old Aug 21, 2008 | 07:53 PM
Truckin4life
hey.... that just makes a good reason to wrassle around in the mud.... It all depends on how you play it out.
Old Aug 21, 2008 | 07:54 PM
DesertStorm's Avatar
DesertStorm
4. No lift blocks under the front leaf springs. A BIG mistake.
