Cam swap question
Old Aug 20, 2008 | 06:16 AM
SRT77's Avatar
SRT77
Cam swap question
If I'm throwing in a new, but mild cam, do I need to replace the valve springs. I'm looking at a Summit kit, part# sum-k5200, which come with lifters and I'll replace the timing set also. I know I probably should, but do I really need to replace the springs?
Old Aug 23, 2008 | 08:46 PM
Iman901's Avatar
Iman901
You dont have to, but if the springs are old you should test them. Also if you want to run higher RPMs you need stiffer springs.
Old Aug 24, 2008 | 03:46 PM
mark a.'s Avatar
mark a.
Springs are cheep. You should use the recomended spring & get rid of the exhaust rotators if your heads have them. I would check push rod length also. Aftermarket cams can have a different base circle.
onetonscs
May 6, 2014 06:49 PM
1972FordCustom
Mar 19, 2006 10:59 AM
Deliverance
Sep 8, 2005 06:43 AM
Rat wagon
Mar 11, 2003 07:39 PM
78SupercabPowerstroke
Oct 28, 2002 01:34 PM
