Simple cams for my 300 I6
Old Sep 7, 2005 | 10:29 PM
Deliverance's Avatar
Deliverance
Talking Simple cams for my 300 I6
what is a good cam for this engine, this truck is a project truck wi th a due date january 15th 2006, and i need to know all little bit more about cams, nothing to extencive to where i have to change alot of other things. Im looking for low-mid RPM range like 1600 to about 3500 or 4500.
if i do change cams, like even if its the base model. should i have to replace my tappits, springs, rods, and so on?
-thank you for the help!
-- Mike
Old Sep 7, 2005 | 11:24 PM
Col Flashman's Avatar
Col Flashman
Thumbs up
Melling Torque Cam is what was put in my 300 I-6, it's a Mild or otherwise know as an R.V. Cam.
A Crane Gold Race Roller Rocker was also installed in my 300 I-6, but had to go w/ a taller Valve Cover.
This is the complete build on my engine @ $4246.64 by JMS Racing Engines, of Monrovia, CA..
300 H.P. @ 4600 rpm & 400 F.P.T. @ 3200 rpm w/ a 10 to 1 C.R.
It idels @ 675 & is smooth as glass, a quarter was placed on top of the Valve Cover & it Did Not move Nor rattle @ least on the Dyno's engine stand anyway.
Ross Pistons 4.060
Hastings Power Flex Rings .060
Federal Mogul Mains .020 Under
Clevite Performance Bearings Std.
Federal Mogul Cam Bearings Std.
Melling Torque Cam
Melling H.V. Oli Pump
Eagle H-beam Rods 6.300 2.100 Rod Journal
ARP Main Stud Kit, Rocker Studs,
Doug Fisher International Damper
Bore 4.060
Power Hone 4.060
Full P&P Intake & Exhaust
Performance valve job
Performance Balance job on Steele Crank w/ in 7 grams
Grind Rod Journals to 2.100
Plumb Intake for Heat via Water Pump
Deck Block to Square
Align hone to Factory specs
Deck block for Zero Deck
Offenhauser C Intake (thinking of going to a D/P)
Holley 1850 600 CFM (thinking of going to a 450cfm)
S.S. Borla 2 into 2 Header
8' of 3" tubes attached to Flowmaster 40's
4 Core Desert Radiator mated w/ the Original Radiator Housing
2 1,200 CPU Electric Fans, on @ 180*, off @ 170* mounted diaginally
MSD 6A Eclectronics Package & Coil
Mid 70's Ford Electronic Ignition (the mallory wouldn't fit?!.)
Old Sep 8, 2005 | 06:43 AM
Motorhead351's Avatar
Motorhead351
Deliverance
If your target rpms are 1500+ then you'd probably be interested in the following:
*Isky 256-supercam part number 331256
*Crower 252 HDP part number 19211
*Comp cams 260H part number 66-237-4
*Crane cams 260/272 part number CRA-503901
*Paw performance part number 11319
*Clifford performance 264H part number 93-3021
You didn't state whether you had an efi or carbed engine. The above are efi friendly without computer modifications.
You wouldn't have to replace your rods, you would need to change the lifters and depending on the miles of the engine the springs, be a good idea to change the springs anyway. Would also be a good time to go ahead and change the timing gears.
Jarryd
Oct 8, 2014 11:27 PM
badbird
21
Feb 25, 2011 11:19 PM
lucky no. 7
Mar 26, 2007 09:10 AM
1994 F250: 351, C6
Mar 9, 2007 08:49 AM
BBF250
30
Jun 9, 2006 06:29 PM
