351C valve train specs
Old Oct 24, 2002 | 06:13 PM
78SupercabPowerstroke's Avatar
I need specs for valve springs for a 73 351C. valve spring pressures and heights. Thanks
I'm putting in a cam that is a little more aggressive, and wondering if we need different springs. the current springs are factory, but relatively new, so i don't want to replace if i can get by with these
Thanks
Steve
Old Oct 24, 2002 | 06:45 PM
Bill_Beyer's Avatar
Bill_Beyer
I'd check with the cam manufacturer to be sure but the general rule of thumb I go by is that if the cam has .500" gross lift or more then I would put new springs in it.
Old Oct 25, 2002 | 10:32 AM
beartracks's Avatar
beartracks
I'm thinkin your old springs are going to be worn out anyway.
Old Oct 28, 2002 | 11:56 AM
James Hewett's Avatar
James Hewett
I have a Crane cam in my C351 and use stock springs and Crane adjustable roller rockers from Summit and it has performed great for at least the last 5yrs. It is what was considered as a torque cam and I don't drag at the dragstrip. Liken street use only.
jim
p.s. make sure to clean and locktite new rocker studs on this set up
Old Oct 28, 2002 | 01:34 PM
Franklin2's Avatar
Franklin2
Steves55
Dec 23, 2014 03:35 PM
'90-f150-302-5spd
Apr 1, 2014 04:07 PM
Steves55
Feb 23, 2014 04:21 PM
Salts
Nov 4, 2013 12:23 PM
minnesota4x4
Apr 6, 2003 10:27 AM
