H.O. alternators
Old Aug 25, 2008 | 12:55 PM
  #46
bdrummonds's Avatar
bdrummonds
[quote=miller_feed;6481093]Yep, Roland. That would look good in there. Match the turbo.
Looks good, Brandon. Is it harder to get to the PCM bolt with the wireing there?[/quote]
Thanks, IDK, haven't tried to reach that yet. If it is, I will probably just use an extension, and a wobble on the socket, and go in from where the airfilter sits.
Old Aug 25, 2008 | 01:49 PM
  #47
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I never thought of going from there. Will have to look and see if it would be easier. But I have little hands, so I can reach it easy enough from the top.
Old Aug 25, 2008 | 03:37 PM
  #48
bdrummonds's Avatar
bdrummonds
See Avatar^^^^. If I could add enough extensions and wobbles and loosen it from the zoodad, I would be better off.
Old Aug 25, 2008 | 03:49 PM
  #49
miller_feed
Yeah, Brandon, I forgot you are a little bigger then I am.
Old Aug 25, 2008 | 04:03 PM
  #50
totin_tools's Avatar
totin_tools
Brandon, Where does the red wire go to on the alternator? I see it goes to a power block but then does it go to a battery, or amp, or something else.
Old Aug 25, 2008 | 04:15 PM
  #51
bdrummonds's Avatar
bdrummonds
Drivers side positive battery post.
Old Aug 25, 2008 | 08:48 PM
  #52
totin_tools
O I C, I saw Dan mentioned doing something like that.
Old Aug 25, 2008 | 09:48 PM
  #53
Tenn01PSD350's Avatar
Tenn01PSD350
That is a sharp looking alt BD. I likey. Hope it is the fix.
Old Aug 25, 2008 | 10:17 PM
  #54
parkland's Avatar
parkland
I hope it works out too, but whatever happens, it looks friggin sweet, and I wish i had one!!!
handyandy123
Jun 6, 2014 08:17 PM
92blue on uhhhh blue
Dec 21, 2012 01:34 PM
Pitcrw6
Aug 26, 2012 12:59 PM
Fireman_dave
Nov 13, 2011 04:58 PM
