H.O. alternators
Old Aug 17, 2008 | 10:13 PM
  #31
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Come on Brandon, you know you want the chrome one!
eBay Motors: FORD DIESEL TRUCK CHROME HIGH OUTPUT ALTERNATOR 98-03 (item 160266232094 end time Aug-27-08 02:25:45 PDT)
Old Aug 17, 2008 | 10:23 PM
  #32
bdrummonds's Avatar
bdrummonds
Originally Posted by strokin_it7.3
Dammit Kris, I didnt even see that one. its only 200amps, but IT'S SHINEY, I like shiney, I will inquire about this in the AM
Old Aug 17, 2008 | 11:38 PM
  #33
parkland's Avatar
parkland
100 amps at idle... full output at 1200 RPM's..
doesnt get much better than that....
DING DING DING we have a winner !!!! (sorry)
Old Aug 18, 2008 | 05:34 PM
  #34
bdrummonds's Avatar
bdrummonds
Shiney Won, it will be here Wednesday. Pics to follow.
Old Aug 18, 2008 | 05:43 PM
  #35
F250_'s Avatar
F250_
Hey Brandon.... Does your new shiny come with a heavy duty voltage regulator and rectifier like those offered at the Quick Start website? Or is that not really necessary to go that far?
BTW.... DC's Ford Blue powder coated alternator sure does look good, too!
Old Aug 18, 2008 | 08:04 PM
  #36
nhill2090's Avatar
nhill2090
Brandon,
Are you going to wire a 4 gauge wire to your battery from your alternator like they suggest?
Old Aug 18, 2008 | 09:05 PM
  #37
PowerstrokeJunkie
You're welcome
Old Aug 18, 2008 | 09:17 PM
  #38
bdrummonds's Avatar
bdrummonds
yes, after talking with them this morning it was confimed that the internal regulator, and the rectifier are heavy duty.
Originally Posted by nhill2090
Brandon,
Yes, The chrome alt. doesnt have the upgraded wiring included, so I am going to make that myself, and aslo find a 225 amp ANL breaker.
You're welcome
Thanks man
Old Aug 19, 2008 | 08:48 AM
  #39
F250_'s Avatar
F250_
yes, after talking with them this morning it was confimed that the internal regulator, and the rectifier are heavy duty....
WOW! That makes that choice about $100 less than the Quick Start unit! I'm flagging this thread for when I upgrade my own alt.
Old Aug 19, 2008 | 02:28 PM
  #40
That_Guy's Avatar
That_Guy
Originally Posted by parkland
or 2 smaller alternators...???
The ambulance package came with dual alternators, I was told by the dealer that they cant order the bracket for the second alternator for some BS reason...Im sure you can find it if its somthing you want to do though.
Good luck with the new alternator Brandon.
Old Aug 19, 2008 | 10:53 PM
  #41
cangim's Avatar
cangim
I went with the 140A version from electric start, I am very happy with it. However, if the DB is essentially the same by all means. Hope with the upgraded wire it solves the problems. I will state that the trailer shouldn't be drawing much if anything from the alt., the back feed from the trailer charger might be taking it out. But think of this, even with a trailer battery at 10V, you have a difference of say 4.5V, with the distance of wire, probably looking at least .5 ohms or so. Max current draw in this situation for trailer would be 9 amps. This is the reason I went with 8 gauge to the trailer plug at the back to help improve the charging efficiency.
I too have added a larger feed wire off of the alternator to run parallel with the stock harness to the driver side battery. I have quite a bit more going on as well, but for a few bucks at any parts store a 3' section of 4 gauge will solve many issues with charging.
Old Aug 25, 2008 | 11:16 AM
  #42
bdrummonds's Avatar
bdrummonds
O.K, since I was outside taking pics of my shackles for another thread, I figured I would close this one out with the pics of my new alternator.
I ordered the DB electrical 200+ amp Chrome alterantor last Monday, and it arrived last Thursday. I installed it right after it arrived, and drove the truck all weekend. I will say that I do think this will solve my issues. I, of course, trickle charged both batts last week before the install, and when I turn the key on and start the truck my FASS fuel pump has a crisper whine to it, even while the GPs are activated. The windings inside this alterantor are HUGE. I am very happy with the purchase...... so far.
EDIT: the test sheet that was included with the alternator showed that it put out 214 amps at 1250 RPMS
pic 1 is a front view
pic 2 is side view
Pic 3 is the ANL fuse block and upgraded wiring.
Old Aug 25, 2008 | 11:35 AM
  #43
That_Guy's Avatar
That_Guy
That thing looks nice. Hope it fixes everything
  #44
mueckster's Avatar
mueckster
Looks good, Brandon. That alternator sure is shiny. I think Rick would want one of those.
Old Aug 25, 2008 | 12:34 PM
  #45
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Yep, Roland. That would look good in there. Match the turbo.
Looks good, Brandon. Is it harder to get to the PCM bolt with the wireing there?
