H.O. alternators
Old Aug 16, 2008 | 03:22 PM
Kwikkordead's Avatar
Kwikkordead
Originally Posted by joegebff
With that being said, if you go with the 220 you have an alternator that doesn't have to work as hard and that has plenty of reserve if needed. Electrically speaking, bigger is usually better.....
The thought occurred to me reading this post, is that if you put in a mondo alternator like that, you also need to upgrade the wiring on the truck.
At the very least run a separate wire to the charge wire for the trailer plug
and install a shunt between the positive post of the alternator and the positive post on the driver's side battery.
That will off load the current from the truck's main wiring harness and all it has to do is to run the truck.
Old Aug 16, 2008 | 09:45 PM
spinge's Avatar
spinge
Dan
Good thought on the wiring between alt and batt. I would suggest add a ground wire as well, also large gauge. I have seen on alot of the big alts that there is a neg terminal as well as a pos terminal, so might as well use them both.
Correct me if I am wrong, but if the 7-pin trailer plug is stock, or at least tied into the stock wiring, there should be a fuse in the circuit for the charge pin, as well as a relay so the pin is dead when the truck is not running. Here is an interesting thought, though - is there something on the trailer that is sending a surge or spike back to the truck to zap the alt.
Old Aug 16, 2008 | 10:28 PM
bdrummonds's Avatar
bdrummonds
Originally Posted by piotrsko
the other problem with alts is heat dissipation. them electron pushing thingeys hate being hot.
I'm guessing that you have a load problem with shore power towing the trailer. Mine will charge the trailer battery and I see a definate 20 amp spike which with the A/c and lights on doesn't leave much room for capacity on the 100 amp alt I have in my truck.
perhaps starting the truck 15 minutes before towing to top off the onboard battery set?
When I tow to the lake I usually run the truck AC, and am listening to the radio, and 98% of the time it is daylight so no headlights needed.
Originally Posted by Kwikkordead
That may very well be it.
Too high of a load somewhere like that and the alternator gets too hot.
Do you have a way of measuring the alt output when you have the fiver hooked up?
I will have Chris bring his ammeter over and we will test it next weekend
The other thing you could do is install a circuit breaker on the charge wire going to the 7 way plug.
They are those little rectangle boxes with two posts on them.
NAPA has them in (I think) 15, 25, 50 amp ratings.
They are self resetting so you don't have to worry about keep flipping a switch, but the downside is they will take a very long time to recharge a dead battery.
And the trailer brakes rely on that same battery in a break-away situation.
I don't know if they use the battery during normal driving or if the trailer gets electric brake power from the truck when it is being towed. Not familiar with that part of the trailer design.
I need to bone up on the trailer wiring diagram also, but since most of my trips are within 100 miles, I wonder if I could put a cut off switch in the center plug line(not have the truck charge the trailer at all.)
Brandon, are you leaving something ON in the TT that might be draining that battery way down or perhaps the TT battery has a shorted cell? You could and probably should charge the TT off shore power before towing. Actually that is probably good advice for all of us.
Joe, nothing is ever on in the camper while towing. Fridge is set to operate off propane while towing, tv antenea booster is off, AC wont work off inverter, all lights are off.
Camper is charged on shore power for at least 3 days before truck is ever backed under it. I need to check the cells in the camper batt.
the 220amp alt from DB electrical comes with upgraded wiring(4 ga, IIRC) and a 250 amp fuse block like you posted above.
Originally Posted by spinge
Dan
good question, but What?
Old Aug 16, 2008 | 10:43 PM
spinge's Avatar
spinge
Well, if nothing is on in the trailer while towing, then there is nothing to do the zapping - I was thinking maybe an inverter or a fridge, but you have that covered.
Does the trailer have a seperate battery for the breakaway brakes? I am not familiar with 5ers, so I am not even sure if they have them. If so, check both electrical systems (main and emerg) on the trailer.
If you want to unhook the charge circuit, and you are working with stock, you can pull the fuse or relay (forget the number of each off the top of my head, but they are there)
Old Aug 16, 2008 | 11:12 PM
bdrummonds's Avatar
bdrummonds
Spinge, the 5er only has one batt, and the brakes are wired into it. I think the trailer brake system is designed to use the power from the truck for the brakes, unless the breakaway is pulled, and then it operates off the camper batt, so I guess the idea of putting a disconnect in the center pin is out. I dont think I would like the idea of a batt with no recharge operating my trailer brakes for a whole trip.
backtracking to the back surge idea, Chris mentioned to me one time that maybe I blew my diodes by plugging the tralier connection into the truck while shore power was still attached(or plugging in shore power at the campsite before truck is disconnected). I have tried to make a conscience effort to make sure this doesnt happen, but sometimes you have little helpers, and I cannot say for sure that this hasnt happened. thoughts?
Old Aug 16, 2008 | 11:26 PM
spinge's Avatar
spinge
Very good thought (I have little helpers too). If there is a battery charger on the trailer, and the shore power is plugged in while the trailer is still connected and truck running, it could very well happen.
Thoughts to solve the problem would be:
1) Some type of battery isolation device (a fancy name for a diode) to prevent trailer power from heading back into the truck.
2) Some type of relay in the power supply to the charger (on the shore power side) that is connected to the battery charge circuit from the truck. The relay would only allow the charger to come on once the truck was disconnected or shut off.
Old Aug 16, 2008 | 11:31 PM
bdrummonds's Avatar
bdrummonds
You know I have seen the isolators at the camper store, and have never really thought much about them, but it may be what I need. I will check into this on Monday.
Old Aug 16, 2008 | 11:34 PM
spinge's Avatar
spinge
Ya can't keep kids from doing what they do, you can only protect your stuff so they don't hurt it too bad - LOL
Old Aug 17, 2008 | 10:14 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
I didnt read much of the post, but while you are at it, get a three or four foot long 4 gauge red cable, put two ring ends on it, attach one end to the driver's side battery and the other to the output post on the alternator. That's alot of amperage when full-fielded to be going through the stock 4 ga cable in the harness that goes to the PASSENGER side battery. Dont worry about a ground, it's already grounded twice.
Old Aug 17, 2008 | 10:24 AM
spinge's Avatar
spinge
Kris,
The only reason I suggested the ground is because alot of times the alt manufacturer will put the terminal on there. That leads me to think that they don't trust the ground straps on the motor, or the mounting bolts and such. In my younger years I did a BUNCH (20 years) of work on fire trucks, and the biggest single cause of electrical problems was bad grounds. Especially for us - MD = salt on roads in winter = corrosion. It is amazing what .5 ohms can do to an electrical system
Old Aug 17, 2008 | 11:36 AM
joegebff's Avatar
joegebff
Gone Fishin for Mark
Wiring Code 7 way Car End # Color Gage Circuit Function connector interior
1 white 10 common ground
2 blue 12 electric brake
3 green 14 tail/running lights
4 black 10 battery charge (+)
5 red 14 left turn/stop
6 brown 14 right turn/stop
7 yellow 14 auxiliary/back up
NOTE: #7 is the center terminal and currently is most commonly used for backup lights.
The trailer brakes operate off of current sent from the brake controller. The trailer battery supplies current only if the break-away is pulled. If you are using the center pin for charging and the camper is using the # 4 pin, perhaps we are on to something. Also take note of the wire guage sizes.
Enjoy this day.
Old Aug 17, 2008 | 02:24 PM
PowerstrokeJunkie
On the front left corner of the engine block, down low, there is a #2/0 ground cable that the driver's side battery - actually goes to.
Old Aug 17, 2008 | 03:25 PM
  #28
spinge's Avatar
spinge
Either with or without a ground wire, the point is make sure that there is a GOOD ground, as even minimal resistance can cause you headaches.
Joe may be on to something if there is a mis-wiring between the trailer and truck, but I would think that the problem would be instant with a fault like that.
Old Aug 17, 2008 | 04:00 PM
  #29
PowerstrokeJunkie
Just read the entire post, and looks like Dan caught my idea before i got a round tuit.
Old Aug 17, 2008 | 09:53 PM
  #30
bdrummonds's Avatar
bdrummonds
Enjoy this day.
Joe, I must have misspoke earlier, according to the wiring charts you are correct, I just didnt have the pin numbers in my head correctly.
Kris, yes I will be upgrading the wire directly from the alt. to the batt, the new one will come with it.
Here is the alt that I am ordering. eBay Motors: FORD F TRUCK 7.3L HIGH OUTPUT ALTERNATOR 98 99 00 01 (item 160273403505 end time Aug-24-08 11:19:37 PDT)
but I will call them in the morning to get it. it should be here wednesday
