94 Lightning Mass Air Flow conversion?
Old Sep 1, 2008 | 11:00 AM
termyt00's Avatar
termyt00
Lightbulb
FYI, I have not tried this nor can i verify, but i have heard of people tieing the two input wires together to one O2 as to fool the EEC. in your case you could just jump from pin x to pin y (being the 2 O2 inputs) of the eec to test.
Old Sep 1, 2008 | 12:03 PM
Conanski's Avatar
Conanski
FYI.. the Ford mass air conversion uses a Mustang computer and it uses this trick to feed both sensor inputs on the computer.
Old Sep 1, 2008 | 11:09 PM
termyt00's Avatar
termyt00
I don't know what the AKCO computer is derived from, whether it be mustang or truck, I know it has the e4od controls built in.
Old Sep 3, 2008 | 06:29 PM
frank13's Avatar
frank13
What are the pin numbers to tie up both o2 sensors?
Old Sep 13, 2008 | 12:51 AM
ford_highboy's Avatar
ford_highboy
I have the same MOB1 computer. lucky for me is i got a great friend inside FORD++++
the MOB1... 95 f150 5.8 E4OD Cali emissions, dual o2's, mass air, sefi. anything else you need to know???
matthew
Old Sep 23, 2008 | 08:10 PM
frank13's Avatar
frank13
Does any body know what are the pin numbers to wire up both O2 sensors?Or can you tell me how to fool the computer to make it think that i have two O2 sensors,thats all i need any help is good thanks.
Old Sep 23, 2008 | 08:51 PM
Blurry94's Avatar
Blurry94
The single ECU mass air conversion kits for the GEN 1 L's (E4OD's) do not use a mustang ECU, of any kind. The only other conversion kits that use a Mustang ECU use the stock ECU to control the transmission, or they utilize a stand along trans controller. IMO an A9 anything with an aftermarket trans controller is a step backwards vs. an E4OD MAF truck conversion.
SWA2004
2004 - 2008 F150
Mar 26, 2010 08:41 PM
frank13
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
17
Aug 15, 2008 07:56 PM
unioncreek
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jan 19, 2007 10:52 PM
blue93explorer
Aug 16, 2004 06:05 PM
