DPFE sensor location on 96 V8 explorer
Old Aug 6, 2008 | 09:02 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
Where is the DPFE sensor on a 96 v8 explorer. The local garage said that is what was causing my check engine light to come on. If anyone has changed one on a similar explorer, what did you have to remove to do it?
Thanks.
Old Aug 6, 2008 | 09:21 PM
jk080's Avatar
jk080
Transmission Rebuilder
Here is some info on that, I hope this will help, sorry its so small.
The place where I got this said it is located on the back of the engine by the firewall.
Also found that some dont have this sensor, and they are being fixed by replacing the EGR valve and solenoid.
Good luck
Old Aug 6, 2008 | 10:13 PM
CobraXP's Avatar
CobraXP
1996 5.0's do not have a DPFE sensor. The late 97's through 2001's did, but not the 96 and early 97's. You probably need to replace the EGR valve itself if you are getting codes that are associated with a DPFE.
I've gotten fairly good at changing them as mine use to eat EGR valves because of the supercharger. The first time I did it, it was a fun job to say the least. Not hard, just time consuming. You will find it on the back of the intake elbow. I haven't done one in a while because I removed the EGR Valve, put a block plate on, and tuned it out with my XCal tuner, but I think it was 2 13mm bolts, plus a vacumm line on the bottom right side.
Old Aug 7, 2008 | 05:22 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
Thanks jk080 and cobraxp. Cobraxp can you give a description of what it looks like? Thanks agian.
Old Aug 7, 2008 | 10:17 AM
CobraXP's Avatar
CobraXP
I know I have a pic at home that I can post later.
Basically, find your throttle body. The TB is bolted to an elbow that turns into the uppoer intake. On the back of the elbow, there is a round bowl looking part that has an orange plunger in it. It will be held on by two bolts.
Old Aug 28, 2008 | 09:42 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
I replaced the egr and the sensor that bolt to it and the check engine light came back on. I borrowed a scanner and the code is P0402 exhaust gas recirculation flow excessive detected, then it has four ovals that are flashing which are cat, o2s, htr, eva and up in the corner it says pending code 02.
So any gueses and how to check.
95BroncoXLT5.8
1978 - 1996 Big Bronco
Dec 30, 2014 09:17 AM
Harley Rider
Nov 23, 2006 10:20 PM
tweb
Modular V8 (4.6L, 5.4L)
Feb 10, 2004 12:55 AM
eldawg4100
Sep 7, 2003 05:09 AM
