Replacing DPFE Sensor on 4.6L
Old Feb 8, 2004 | 07:46 PM
tweb's Avatar
tweb
Question Replacing DPFE Sensor on 4.6L
Hi,
I'm not sure if this is the right place -- but it is a Ford 4.6L modular V8, and the DPFE related posts I've read here doing reseach shows a nice communty....
I've got a 96 Tbird with a 4.6L V8 that is throwing P0401 errors. Everything seems fine other than the MIL is lit and the P0401 error codes. Physical testing of the EGR valve produces the expected results. Everything points to the DPFE sensor being the problem.
Went to replace it and found that the hoses appear to be bonded to the sensor tubes. There isn't a lot of space to work with it, and I don't want to mangle the hoses if I can help it.
Does anyone have any tips for breaking the sensor free from the hoses?
Thanks in advance,
Tom
Old Feb 9, 2004 | 07:06 AM
LxMan1's Avatar
LxMan1
Hi and welcome to the forum.
I would think that you should be able to twist them back and forth a little to break them loose.
Jimmy
Old Feb 9, 2004 | 04:53 PM
gkbid's Avatar
gkbid
Mine didn't want to cooperate as well...it just took persistance with lots of elbow grease.
Old Feb 9, 2004 | 11:38 PM
Stoner150's Avatar
Stoner150
i used a pair of plyers and a little force
Old Feb 10, 2004 | 12:55 AM
tweb's Avatar
tweb
Thanks guys. I was hoping for a silver bullet. On the Tbird at least, the sensor is kind of wedged between the engine and the firewall. No real room to get pliers on them.
Will give it a shot when I can afford to have it laid up for a couple days if I do 'hose it up'.
Thanks again,
Tom
Al_Cuevas
1997 - 2003 F150
93
Aug 13, 2016 08:50 AM
elga
27
Nov 14, 2012 10:25 PM
deejdeej
1983 - 2012 Ranger & B-Series
Jun 10, 2010 09:51 PM
judgebc
Jan 4, 2010 12:50 AM
RGrimes
1997 - 2003 F150
Feb 7, 2006 12:36 PM
