2002 explorer sport DPFE sensor location?
Old Sep 4, 2003 | 12:12 AM
eldawg4100's Avatar
eldawg4100
The vehicle is a 2002 explorer 2 door with 4.0 SOHC engine. Check engine light is on, dealership says DPFE sensor.
Can anyone give as much info as possible?
Location, how to change, what it looks like?
thanks very much
Old Sep 4, 2003 | 11:16 AM
eldawg4100's Avatar
eldawg4100
anyone?
the dealer also "recommend" flush injectors, decarb throttle body and intake............
ill just change the DPFE sensor first, if i can find out where it is!
thanks
Old Sep 4, 2003 | 12:07 PM
CNTHOR's Avatar
CNTHOR
The DPFE sensor should be easy to locate.
It should have two vacuum lines and one electrical connector coming out of it.
On my '95 it is a silver square about 1.5 inch bolted on the right side of the valve cover.
The vacuum lines run down close to the EGR valve (it is the only valve with a Pnuematic "mushroom top" on it)
The two vacuum lines plug into a pipe which comes from the EGR valve and goes to the intake manifold on the back of my engine.
Old Sep 7, 2003 | 05:09 AM
kmans777's Avatar
kmans777
It is as CNTHOR descrides it. On my 96 Explorer, it's located on the left side of the engine, close to the EGR valve. When I changed mine, the nipples where the lines connected to were corroded and plugged. Very easy to access and change. Can't remember price but pretty sure it was less than $50.00
cjben
Jul 1, 2017 09:56 AM
Don Gor
New Member Introductions
Sep 20, 2016 02:17 PM
GreaseGun Joe
Oct 15, 2015 04:44 PM
dwimood
Nov 22, 2011 02:20 PM
autocarecenter
Jul 22, 2004 08:05 AM
