removing EGR on 95 5.8 with DPFE sensor
I replaced mine. To get the egr valve out, i had to remove the sensor and the bracket that held it in place because it was in the way then i disconnected the rubber tubes from the egr line tube. be careful not to bend the smaller metal tubes comming off the egr line. they cracked easily at the welds.
What did you do about the cracked metal tubes of the DPFE?
i have a 1996 5.8 . I currently have codes 171/174 Sys Too Lean for bank 1 and 2. i didnt end up replacing the egr or the sensor they all looked fine. i was removing it to look for carbon build up or anything that might be clogging the lines. i ended up wiping it down, installing everything back and replacing the rubber tubing. while accelerating at high speeds i can hear ratteling which i think is comming from the catalytic converter, which i havent gotten around to replacing yet. i think thats whats giving me those error codes, but i'm not an auto mechanic. So since i've gotten the truck what i have been doing is slowly going over the engine cleaning and looking for broken lines/wires/ or leaks. I looked around for a replacement EGR line and couldnt find one. The ones i saw online were straight tubes and i needed one that had the two smaller tubes comming off the side for the sensor. I read a post online that said just get a new one because they are better quality blah blah blah. i got one from the dealership for 50 bucks. After looking at the new one. i think i could have just re-welded my old one back together myself and had similar quality. I'm not sure what codes your troubleshooting, but here is a link to ford pdf's and service manual dvds.
http://www.forddvds.com/index.htm
My 95 is under the OBD1 system. I'm trying to diagnose a trouble code 332, with a CEL. 332 is "insufficient EGR flow detected." The EGR is ridiculously hard to get off, but I'm almost there. I also want to clean it up, and see if that clears the code.
I would think our engines are almost identical, but maybe not. If I broke one of the thin metal tubes coming from the exhaust manifold to the DPFE, I'd be in BIG trouble. I can see the nut at the exhaust manifold, but as usual for this truck, it's impossible to get to. I think I would have to remove the motor to get to it.
One time I had a mysterious rattle from under the truck. It turned out to be a bolt that had wedged itself against the exhaust pipe. I must have picked it up from the road somehow. Hopefully yours is as simple.
SteelHorse4x4
04-09-2017 12:12 AM
icantdo55
01-29-2014 07:11 PM
