Changing '04 rear fluid
Old Aug 8, 2008 | 04:49 PM
pcf_mark's Avatar
pcf_mark
This may sound like a really stupid question buuuut is the very large plug with the very large sqaure over 1" the drain plug on the back of the rear cover? It looks enormous compared to the fill which I think is the small plug about half way up the back.
I never worked on the independent rear models and do not want to screw up!
Any external way to identify if I have an LSD or not?
Old Aug 8, 2008 | 09:41 PM
srercrcr's Avatar
srercrcr
I'll let somebody more in the know answer you, but I just wanted you to know I'm pretty sure that rear end is spec'ed for synthetic fluid.
Old Aug 8, 2008 | 09:45 PM
steve(ill)'s Avatar
steve(ill)
your right. on a regular truck like the F150, you remove the rear cover and clean inside. on the EXP independant you have an aluminum box rear pumpkin. There is a large plug at the bottom to drain, and the normal 1/2 inch pipe plug to fill about half way up. i use the 3/8 ratchet to remove the top plug, i forget how big the bottom is, if it is 1/2 inch ratch or i think you need a 3/4 square adaptor for the ratchet. i normally park front end up a little so everything runs to the back and drains good. let it set for 20 minutes to get everything out. THEre should be a sticker on the door that tells you if you have LS or not. EIther way, put 75 w 140 FULL synthetic oil in the back, and a 7 oz tube of friction modifier that you can get at Auto Zone. It helps with the gear whine even if you dont have a LS axle.
Old Aug 8, 2008 | 09:46 PM
steve(ill)'s Avatar
steve(ill)
Axle Codes
L - Limited Slip Differential
C - Conventional Differential
Code Ratio
18 3.08C
19 3.55C
24 3.54L
25 4.10C
26 3.73C
27 3.31C
28 3.73C
B5 4.10L
B6 3.73L
H9 3.55L
Old Aug 8, 2008 | 09:48 PM
steve(ill)'s Avatar
steve(ill)
these are the EXP codes below. the above are for the F150-- sorry.
Axle Codes
Code Ratio
41 3.27C
42 4.10C
43 3.08C
45 3.55C
46 3.73C
D1 3.27L
D2 4.10L
D4 3.73L
D5 3.55L
Old Aug 9, 2008 | 06:43 AM
pcf_mark's Avatar
pcf_mark
Thank you for the confirmation. I am trying to quiet the whine too! In goes the friction modifier too...
Old Aug 9, 2008 | 10:10 AM
Steina's Avatar
Steina
CO River Rat
Mark -
If your '04 has the 2" receiver hitch and 7-pin round trailer receptacle, then you've got the 3.73 LS rear end.
Steve
Old Aug 28, 2008 | 09:41 PM
fordmerc's Avatar
fordmerc
There is a tag on the rear diff. The first thing on the tag will either be 3 55 or 3L73. The L in the 3 73 means limited slip. the numbers are the gear ratio
Old Aug 28, 2008 | 11:15 PM
jasongt06's Avatar
jasongt06
The big plug is a 3/4 inch. You can get an adapter set at Harbor Freight for $3.00 .
jasongt06's Avatar
jasongt06
Also, if your Exp has AdvanceTrac it will not have limited slip.
MClogger
Large Truck
Mar 19, 2016 06:49 PM
hillcountryflt
19
Oct 2, 2015 01:09 PM
DieselRugger
26
Dec 19, 2011 10:30 AM
BoSoxFan
Escape & Escape Hybrid
May 4, 2011 10:36 AM
89ford73
27
Oct 29, 2008 10:01 PM
