PLEASE Help.
Old Aug 6, 2008 | 07:00 PM
Flea's Avatar
Flea
Like maybe 30min to hour and on the charger. I am watching my batteries slowly drop in volts now down to 12.2 to 12.5 on both sides. The smaller connector on the alt on top is loose and wiggles and the other black one on top wiggles a bit too. The battery lead to the alt is tight. Should I cut and splice these wires or what?
Old Aug 6, 2008 | 07:01 PM
Flea's Avatar
Flea
I know where the IPR is but I guess that you just loosen the nut on the IPR?
Flea's Avatar
Flea
The IPR is the thing that my rather your mod "Coonmod 20K" is on, right?
Old Aug 6, 2008 | 07:11 PM
c00nhunterjoe's Avatar
c00nhunterjoe
the resistor is on the icp sensor, the ipr is down into the valley sticking out of the high pressure oil pump. has a thin 3/4 nut on it
Old Aug 6, 2008 | 07:13 PM
Flea's Avatar
Flea
What do I do to it? How do I tell it is bad?
Old Aug 6, 2008 | 07:24 PM
c00nhunterjoe
when youunscrew it from the back of the pump you will see a pair of o-rings on it, about the size of ac condensor o-rings, odds are the round one is split. this allows the engine to operate while the oil and ring are cold but as the engine heats up and the oil thins and rubber expands then it allows the oil to bypass the regulator and the pump loses its ability to hold high pressure oil.
Old Aug 6, 2008 | 07:58 PM
Flea's Avatar
Flea
I found it. I will have to remove it tomorrow. Do I need any special tools, like crows foot wrench?
Thanks again for your help.
Fletch
Old Aug 6, 2008 | 08:15 PM
c00nhunterjoe
can be done with basic hand tools
Old Aug 6, 2008 | 08:21 PM
tjbeggs's Avatar
tjbeggs
PULL YOUR DIPSTICK!!! Sounds to me like the HPOP reservoir is emptying. If the crank case is full next time it dies remove the plug on the reservoir and see if its full.
Old Aug 6, 2008 | 08:26 PM
c00nhunterjoe
he didnt mention long crank times after its been towed home though? or i may have missed it. which is it...???? ARGHH
Old Aug 6, 2008 | 08:40 PM
tjbeggs's Avatar
tjbeggs
He didn't mention it (So you didn't miss it) but its certainly worth the few minutes it will take and its the first two steps to checking for a HPOP issue.
Old Aug 6, 2008 | 08:58 PM
c00nhunterjoe
cant hurt.
Old Aug 7, 2008 | 08:36 AM
  #28
Flea's Avatar
Flea
What plug do I pull? Where is it on the HPOP
Old Aug 7, 2008 | 08:46 AM
  #29
tjbeggs's Avatar
tjbeggs
The fill plug is right behind the upper rad hose
Old Aug 7, 2008 | 08:53 AM
  #30
Flea's Avatar
Flea
So got in it this morning and it cranked and took a long about 10 sec crank to get it going. It then fired up and ran like crap and dies about 20 sec later. Then cranked again and she ran and ran crappy. So, no long crank time but I will pull the plug. How do I know if it is low? What is considered full?
Thanks again for all your guys help. You guys are invaluable. I will also pull the IPR.
