PLEASE Help.
Old Aug 7, 2008 | 05:55 PM
  #46
c00nhunterjoe's Avatar
c00nhunterjoe
wow, alot has been going on since i went to work today. lots of reading to catch up. at this point yuo really need a scan tool that can read live data and you need to get a live fuel pressure reading when the truck is acting up. its weird that you can go 30 seconds or 30 minutes between problems.
Old Aug 7, 2008 | 06:00 PM
  #47
79f-250custom's Avatar
79f-250custom
Originally Posted by 79f-250custom
i really did not read this thread all to well so i dont know if you checked this.
if i was in your boots i would pull off both valve covers and check the wireing harnes's. they may look good from the top side but could be fried on the other side.
just my .02 cents.
Mitch
^ dont over look this.
and from reading your Sig, it sounds like your making your own fuel. could you have made a bad batch? another thing to think about.
but id still say pull off your valve covers and check out dem der wires
Mitch
Old Aug 7, 2008 | 06:14 PM
  #48
Flea's Avatar
Flea
I will pull valve covers.
New info:
Really hard to open fuel filter. When I do air blasts out and feels like it is building lots of pressure. Could this be a problem and lead to mine?
I don't make my own fuel. It is waste veggie and i have changed all the filters.
Should I get a new schrader valve?
I am on my way to get the scan tool. But no CEL. Will codes show up?
Old Aug 7, 2008 | 06:16 PM
  #49
c00nhunterjoe
hmm, shouldnt do that... well i assume the truck isnt running. check your regulator to see if its sticking
Old Aug 7, 2008 | 06:19 PM
  #50
79f-250custom
dumb ?, do you have fuel in your tank? maybe its just pumping air into the fuel filter canister and building air pressure. just a though lol
Mitch
Old Aug 7, 2008 | 06:57 PM
  #51
Flea's Avatar
Flea
So, got a scantool from O'reilly's and it says CEL is ON, (yet I don't see one on the dash), and it says there are no codes.
Truck won't start right now. charging batteries from the cranking.
Old Aug 7, 2008 | 06:59 PM
  #52
Flea's Avatar
Flea
Coon, which regulator do you mean? IPR? How do I pull this. I ended up pulling a oil line thinking that was it. I guess it is on the firewall side of the HPOP and under the fuel bowl?
how do I get to it?
Old Aug 7, 2008 | 07:00 PM
  #53
Flea's Avatar
Flea
Coon, should I not pull the vc's?
Old Aug 7, 2008 | 07:31 PM
  #54
Flea's Avatar
Flea
Now the tach doesn't move at times. I am thinking about pulling and replacing the cps? What could cause a cps to go bad so quick?
I switched from synth oil to petro based. Last oil analysis said I had a high lead content.
Old Aug 7, 2008 | 07:34 PM
  #55
c00nhunterjoe
does this scan tool give live data or will it just pull codes?
if the tach isnt moving you have wiring or a bad cps, sometimes you just get a junk one.
the reg i spoke of was the fuel regulator on top the fuel filter housing.
was the truck running and died or has it been sitting. what is the scenario fo rthis nostart?
Old Aug 7, 2008 | 07:40 PM
  #56
Flea's Avatar
Flea
It just pulls codes. How do I check the fuel reg.?
The truck ran for about 30 min or so and quit. Has been sitting for an hour. cranks and cranks and got jumper cables on one batt and trickle charger on the other.
Old Aug 7, 2008 | 07:44 PM
  #57
c00nhunterjoe
it really sounds liek an ipr issue. i recomend removing it and inspecting the o-rings since you have no way to view pid data
Old Aug 7, 2008 | 08:16 PM
  #58
Flea's Avatar
Flea
Okay. truck running now and same start sequence. CPS changed. How to I go about Checking IPR? What do I have to remove and how long should it take a newbie to do?
Old Aug 7, 2008 | 08:20 PM
  #59
c00nhunterjoe
first off, how long did it sit after it died befiore restart?
second , let it run another 30 minutes and see if it dies again.
if so then we'll check the ipr. its not too bad, first timer...maybee an hour? the trick is gettting your big hands into that little space. its just 1 connector, i 3/4 nut. then the whole back falls off of it. then a 1 1/8 wrenc(i beleive) is used to lossen the regulator and it just unscrews.
some find it easier to remove your fuel pressure regulator to get more room.
Old Aug 7, 2008 | 10:14 PM
  #60
westcoastslider's Avatar
westcoastslider
I'm thinking air leak in the fuel system. How long/many miles have you been running WVO?
