Sponsored by: Real Truck
Diff covers....
Old Aug 6, 2008 | 12:37 AM
fivonut's Avatar
fivonut
Diff covers....
Can't believe I forgot this. I had to do some hauling this past weekend and while checking everything over I found this:
Talked to the local dealer and the next day I swapped it for this:
Much prettier
Old Aug 6, 2008 | 01:30 AM
ReAX's Avatar
ReAX
Well, certainly less oily on the outside. I know it's cheaper, but I still prefer the mag hy-tech look.
Old Aug 6, 2008 | 08:11 AM
dkf's Avatar
dkf
I put that aluminum cover on my 04' about 4 months ago. Shure looks better than the factory steel one and now I got guys checking out my pumpkin.
Old Aug 6, 2008 | 08:29 AM
rugermack's Avatar
rugermack
You can buy 4 of the factory aluminum diff covers for the price of one mag tech. Wasn't a hard choice for me.
Old Aug 6, 2008 | 08:36 AM
bryyce62's Avatar
bryyce62
Copy that.
I'll keep the extra $150 every time. I got a kid in college!
Nice mod. BTW.
Old Aug 6, 2008 | 09:16 AM
yukondiesel's Avatar
yukondiesel
Aluminum+fins=cooler lubricant? ("That's a GOOD thing": Martha Stewart)
Old Aug 6, 2008 | 11:12 AM
rugermack's Avatar
rugermack
Yes, cool is good.
Old Aug 6, 2008 | 11:37 AM
fivonut's Avatar
fivonut
AND I shouldn't have anymore rust issues....
Old Aug 6, 2008 | 11:39 AM
cartmanea's Avatar
cartmanea
I'll be getting the '08 cover when I get a chance to put my 4.30s in. The other aluminum covers are retardedly expensive, and I am a kid in college!
Originally Posted by bryyce62
Copy that.
Nice mod. BTW.
Old Aug 6, 2008 | 11:42 AM
RagdollRacer's Avatar
RagdollRacer
Where did you get this??? How much did it cost??? I cannot justify a Maghitech and I think this one looks just fine. My truck is lifted and frankly the pumpkin is, well ... ugly. (the one under the truck...)
Thanks,
Old Aug 6, 2008 | 11:46 AM
fivonut's Avatar
fivonut
Local Ford dealer for $59. Go to FTEPartGuy's website if you don't need it today. He has em for $42ish plus shipping. I'd hurry before Ford catches on and starts raising the price like they did with the 08 Mirrors.
Old Aug 6, 2008 | 11:58 AM
RagdollRacer
Thanks fivonut,
Do you have any suggestions on installation? I will probably need new gaskets and new fluid. Any suggestions about diffy fluid for the SD?
Old Aug 6, 2008 | 11:59 AM
dkf's Avatar
dkf
I got mine from DieselManor. DieselManor - Ford Sterling Differential cover Comes with new longer bolts with the extra corrosion resistant plating. S&H was around $9.
Old Aug 6, 2008 | 12:32 PM
rugermack's Avatar
rugermack
You don't use a gasket, just RTV. It should come with the longer bolts. Fluid -synthetic with additive, or make life easier and just use Royal Purple. RP already has additive in it.
Old Aug 6, 2008 | 12:45 PM
fivonut's Avatar
fivonut
It does not come with longer bolts. You have top buy separately. I went to my local hardware store and got (12) 5/16 X 18 X 1" grade 5 bolts and washers for $1.5x / lb. No gasket, I used an RTV called The Right Stuff ( I swear by it ). There's a tag on the diff that calls for 75W-150 synthetic. Can't tell you exactly how much, I bought a 2 gallon container of it and used at least 1/2.
