Garrett vs Turbonetics
Old Jul 22, 2008 | 02:23 AM
Chance_Thomas's Avatar
Chance_Thomas
Garett GTP38R
290 HP
550 FT/LBS
40psi
Cost around $1,787.00
Turbonetics
400 +HP
700 +FT/LBS
28 PSI boost
cost around $2,000
I just was a little curious so had to look it up.
Old Jul 22, 2008 | 03:41 AM
ron's power stroke's Avatar
ron's power stroke
is this the BB TN ??
Old Jul 22, 2008 | 04:33 AM
Chance_Thomas
BB TN 1.00 A/R
Old Jul 22, 2008 | 06:08 AM
Izzy351's Avatar
Izzy351
What are these numbers? Something seems goofy.
Old Jul 22, 2008 | 06:38 AM
John311t's Avatar
John311t
Yes it does, sounds like one is showing what the turbo has been proven to, the other one is just showing perhaps what a drop in replacement can do with a chip.
As of right now I am looking at a garrett BB, instead of the TN units. A truck ran both turbos, the TN ended up eating itself, so they installed a Garrett and gained PSI and ran faster at the track.
Old Jul 22, 2008 | 06:45 AM
Chance_Thomas
I took this information off two websites selling these turbos. The two numbers represent HP and torque.
Old Jul 22, 2008 | 07:14 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
$2,000.00 for the TN. Stay away from that place. I got mine $505.00 lower then that delivered to my door. The TN BB will boost much more than that. I thought you couldn't get a Gattet right now. Redoing it or something.
Old Jul 22, 2008 | 08:32 AM
Izzy351's Avatar
Izzy351
That's what I was thinking, but then the boost numbers are kind of backwards. Just goes to show you that you have to take everything with a grain of salt if Marketing wrote it...
Old Jul 22, 2008 | 08:40 AM
John311t's Avatar
John311t
I think they are back out now. They had to re-making there casting for it since it was wore down I think was the problem.
Old Jul 22, 2008 | 08:47 AM
Pocket's Avatar
Pocket
Yeah, those are marketing numbers only. I pay as much attention to those as I do the dyno sheets from Banks Power.
Everyone's already seen the GTP38R on 450+ hp trucks. TN-BB is still kinda new, but it's on a few 400+ hp trucks and seems to like it.
Old Jul 22, 2008 | 08:24 PM
DCSpecial's Avatar
DCSpecial
If I were to get a turbo it would be the Garrett Ball Bearing. I've had friends who ran them back when they had 7.3s and they all liked it and had good luck with it.
Old Jul 24, 2008 | 08:13 PM
Dieselmanor's Avatar
Dieselmanor
FTE Sponsor
We've had no problems getting the Garrett BB GTP38R. Sold quite a few in the last few weeks too. As far as those numbers, you need to make sure you're comparing apples to apples. You cannot run the Garrett, or TN w/o a chip. The larger wheel requires a chip to be running at 50HP or more, otherwise you'll actually loose power and boost. A stock truck w/ the BB turbo just does not have enought umph to run it properly. I run mine at 75-100 additional HP on the the TS chip. This gives me the best fuel economy in my truck.
Garrett also sells a new BB cartridge for the stock turbo. It will have some of the same benifits (quicker spool up, etc) and does not require the chip. The cartridge is a complete unit with new wheels. Basically the housing stays stock but the wheels and bearing are new. The only reason why we don't sell too many of them is because of the price. They cost about 400 less than a whole new GTP38R. For 400 bucks, most people opt for a whole new turbo with larger 88mm compressor wheel.
Old Jul 24, 2008 | 09:00 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Yep, that is total bunk. If I have to I can dig up my old turbo efficiency maps where you can compare them. This is not rocket science, at least for us, as they are what they are and the math has been done. I have posted both here in the past.
I say get the GTP38R with the non-wastegated non-ebv 1.15 housing. I have just about a 1 to 1 drive pressure ratio now. There is no surge.
RacinNdrummin
52
Dec 9, 2016 11:24 AM
Jamaika
13
Apr 6, 2015 05:49 PM
03 SVT VERT
2015 - 2020 F150
Oct 1, 2014 11:23 PM
52willys
Jun 16, 2014 08:36 AM
Silver Streak
32
Aug 12, 2003 06:02 PM
