ABS Light and Dead Speedo
Old Jul 20, 2008 | 08:15 AM
derekmj64's Avatar
derekmj64
Hello,
Last night when I got into my truck (2001 F-250 7.3L), I noticed my ABS light was on as well as the speedo didnt work. After a while the overdrive light started flashing. Im not sure whether it is the VSS or not. I just replaced it about 6 months ago. If you could help me out I would really appreciate it. Thanks
Derek J.
Old Jul 20, 2008 | 08:17 AM
ron's power stroke's Avatar
ron's power stroke
sounds like VSS ... try cleaning it...if you can pull codes..go ahead and see what shows up... not sure where you got your VSS but Napa has them for 10 to 15 bucks..they call it the ABS sensor...
Old Jul 20, 2008 | 08:52 AM
zx250's Avatar
zx250
Of the next Riffraff East
You could try cleaning it. If you have a bunch of gunk build up in there, it may need to be changed out as well. Check you wire connection as well.
Old Jul 20, 2008 | 09:33 AM
Kwikkordead's Avatar
Kwikkordead
Make sure that the weather seal is still there in the plug.
What I am wondering is if the female part of the plug is corroded out and you have to replace the connectors.
Old Jul 21, 2008 | 09:35 PM
playdough1's Avatar
playdough1
I've had all this intermittently , but now the ABS is on always 5 sec. after pulling out. What is VSS?
Thanks boys, must have saved about a grand just lurking this site.
Old Jul 21, 2008 | 10:02 PM
John311t's Avatar
John311t
VSS sensor is in the rear axle. Its the only sensor on top of the axle. Its also known as vechical speed sensor. It only about 10$ from a parts house.
Old Jul 21, 2008 | 10:11 PM
gunfrk's Avatar
gunfrk
When you pull it out, take your time. Don't put too much pressure on it, as it will break, leaving the plastic cup/end still in the housing. It can be removed with a sawzall blade as a pick/punch to pull the remainder out.
Old Jul 21, 2008 | 10:16 PM
danskool's Avatar
danskool
Go Bills !
MOTORCRAFT® SENSORS FOR FORD, LINCOLN OR MERCURY VEHICLES.
Look something like this not sure on our trucks if it is the same? My older motorhome looked like this one. driver side top rear diff.
Old Jul 21, 2008 | 10:17 PM
Ponyboychris's Avatar
Ponyboychris
IIRC, that's what the VSS looks like.
Old Jul 22, 2008 | 06:21 PM
playdough1's Avatar
playdough1
Thankyou, Thankyou, Thankyou, once again the forum saves me from going to Ford and bending over.
NAPA part #530780 at $15.29 after tax and all flashing overdrive lights , ABS and dead speedos are no more. So simple, a couple local garages couldn't interface with my truck for codes so I was headed to Ford, whew!
Even got the door ajar light out with the wd40 soak down on all doors.
Thanks again, friends and neighbors think I actually know what I'm doing.
Old Jul 22, 2008 | 06:25 PM
ron's power stroke
welcome to your new home..pull up a chair and do some reading....we can help you spend what we help you save to...
Old Jul 22, 2008 | 06:52 PM
danskool's Avatar
danskool
Go Bills !
I got mine for a 1992 at autozone. Don't list it for our trucks. Went to napaonline and they don't list it either. Pull it up for a 1992. it shows. Wierd.. O well. I will stop in there. Cheap enough to get one and toss in tool box while i travel
Good you posted napa part number for others to see.Thanks. I save that stuff in a word document for future reference.
Old Jul 22, 2008 | 06:54 PM
ron's power stroke
Old Jul 22, 2008 | 07:12 PM
danskool's Avatar
danskool
Go Bills !
Yep searched, ebay,motcraft,autozone,napa (with 530780) as a part number and descriptions of vss sensor,abs sensor,speed sensors, etc. nothing.
Old Jul 22, 2008 | 07:18 PM
Ponyboychris
Read thru this stuff and really impress your neighbors...
Welcome to guzzle's Ford PSD Web Page
Powerstroke Mods and Maintenance
sonicsaleen
Feb 20, 2024 04:58 AM
Rpaulo
New Member Introductions
Jun 1, 2016 02:59 AM
slashfan7964
Apr 3, 2016 08:40 PM
ramrod7373
Dec 29, 2012 08:39 AM
RacerLT250R
Jul 22, 2009 09:24 PM
