no start???s
Old Jul 15, 2008 | 08:52 PM
  #31
powerstrokeddiesel's Avatar
powerstrokeddiesel
it was a guage and it was between 2 and 3 thousand psi... on the guage... and i am not sure on the ipr i tried changing the cps again today and i am going to again tomarr... but i am prolly gonna pull it in the garage tomarr and pull the vcs... and it started again today but it died right back out... and other ideas guys i am at a loss...
Old Jul 15, 2008 | 08:56 PM
  #32
powerstrokeddiesel
how do i check the ipr??? and does my hpop being so good mean this when i get it to start was the break down to make me upgrade to stage 1s??? lmao i sure hope so... also i think my turbo blowed... lol and i also need a dp tuner to keep it from doing this again hahaha
Old Jul 15, 2008 | 08:59 PM
  #33
tjbeggs's Avatar
tjbeggs
I would not pull the VC's yet. You can test the wiring with an ohm meter
Glow Plug Replacement and Relay Swap
I would pull the VC connectors and look for burned pins like Joe said earlier. But everytime I have seen harness issues there is a code that follows it.
Old Jul 15, 2008 | 09:00 PM
  #34
tjbeggs's Avatar
tjbeggs
HPOP system seems fine. it wouldn't be building those pressures if there was an issue. Its either fuel or electrical now.
Old Jul 15, 2008 | 09:04 PM
  #35
powerstrokeddiesel
what about the ipr or is it fine??? and what do i need to check fuel wise???
Old Jul 15, 2008 | 09:07 PM
  #36
tjbeggs's Avatar
tjbeggs
ICP should be fine. the pressures are good though it is interesting that 1280 keeps popping up. Check cranking fuel pressure again just for fun.
Also just to double check watch for Tach movement and WTS light.
Old Jul 15, 2008 | 09:14 PM
  #37
c00nhunterjoe's Avatar
c00nhunterjoe
if memory serves me tonight the 1280 is icp out of range? if that is the right code then it is setting because he has 2500 psi while cranking, that is not good. the only reason i can thinkof to have that kind of pressure while cranking is a blcokage in the drain of the ipr
Old Jul 15, 2008 | 09:15 PM
  #38
powerstrokeddiesel
sorry bout that tim i meant to say ipr and i got 50 psi on my cranking fuel pressure at the valve and i hsve tach movement and i also have a wts light... so what do i need to check now... and what all stuff fuel wise do i need to check???
Old Jul 15, 2008 | 09:17 PM
  #39
powerstrokeddiesel
yea coon the 1280 is icp out of range
Old Jul 15, 2008 | 09:22 PM
  #40
c00nhunterjoe
2500 psi while cranking is the problem in my opinion, where where you measuring the oil pressure at?
Old Jul 15, 2008 | 09:26 PM
  #41
powerstrokeddiesel
second hole back on the passenger side head...
Old Jul 15, 2008 | 09:45 PM
  #42
c00nhunterjoe
was it the same on the driver's head?
Old Jul 15, 2008 | 09:51 PM
  #43
powerstrokeddiesel
did not check it i will tomarr... and thanks again for the help i will need you all again tomarr tho.. and any other ideas are very appreciated
Old Jul 15, 2008 | 10:14 PM
  #44
the breeze211's Avatar
the breeze211
got a ford f250 1996 power stroke quit running the high pressure tank was low so filled it up and the truck starts and runs till the tank is dry again any help would be great thanks in advance
Old Jul 16, 2008 | 07:32 AM
  #45
tjbeggs's Avatar
tjbeggs
1280 is ICP out of range Low
1281 is ICP out of range high
1282 is excessive ICP pressures
I think the pcm keeps command higher and higher ICP until the truck starts.
