cps help
Old Jul 10, 2008 | 04:00 PM
Benny2002's Avatar
Benny2002
cps help
truck died with grey cps in, switched back to old black one, made it 20 miles now black I guess is dead. Got fuel and pumping any help?????
Old Jul 10, 2008 | 04:26 PM
zx250's Avatar
zx250
Of the next Riffraff East
Any other symptoms, CEL, gauges, lights.?
Benny2002's Avatar
Benny2002
on the side of the road, anyone?
Old Jul 10, 2008 | 04:27 PM
Pocket's Avatar
Pocket
Two CPS's in a row tells me it's not the CPS. I'm betting a sticking IPR.
Benny2002's Avatar
Benny2002
everything is normal, only code is for air intake heater, always there
Old Jul 10, 2008 | 04:28 PM
Pocket's Avatar
Pocket
You can also check the nut on the back of the IPR to see if it's loose.
Old Jul 10, 2008 | 04:29 PM
zx250's Avatar
zx250
How is it dying? Slow and painful or sudden stop?
Old Jul 10, 2008 | 04:30 PM
mndiesel's Avatar
mndiesel
ipr is where I would start
Old Jul 10, 2008 | 04:31 PM
zx250's Avatar
zx250
One more thought, oil level.
Old Jul 10, 2008 | 04:34 PM
Benny2002's Avatar
Benny2002
how can I check IPR just put in new grey one and no start
Old Jul 10, 2008 | 04:35 PM
Benny2002's Avatar
Benny2002
Oil is good IPR pic ?
Old Jul 10, 2008 | 04:52 PM
Benny2002's Avatar
Benny2002
Can I fix the IPR from the side of the road, I need a pic i forgot which one it is. Thx u guys
Old Jul 10, 2008 | 04:59 PM
farmdad's Avatar
farmdad
It is hidden under the HPOP. Kind of tough to get to but can be done. To change the whole IPR you need a really deep well socket but I don't remember which size. Others will help with that. You can check the tin nut that holds the coil on the IPR with pliers......
Old Jul 10, 2008 | 05:09 PM
zx250's Avatar
zx250
Hope this helps. I belive a bad IPR or ICP will throw a code.
Old Jul 10, 2008 | 05:11 PM
F350-6's Avatar
F350-6
Do all your dash lights act normal when you're trying to start it back up? glow plug light come on then go off like normal, etc?
Can you describe how it died? Sudden like key was turned off, or bucking and stumbling?
I don't have a pic of the IPR either, but look where the oil lines come off the HPOP. If you're standing in front of your truck they come off the right side as your looking at it. The IPR is on the side furthest away from you pointing back at the cab of the truck. It's just around the corner from the HPO lines.
