Sponsored by: Real Truck
Lawsuit reopens
Old Jul 10, 2008 | 02:40 PM
MarkMoore's Avatar
MarkMoore
Lawsuit reopens
Lawsuit reopens alleging faulty Ford Power Stroke diesels - MotorTrend article
Old Jul 10, 2008 | 05:53 PM
gaspowerSD's Avatar
gaspowerSD
this could get interesting. why is this guy complaining though if, per the article, he still has no problems to speak of 4 years later?
Old Jul 10, 2008 | 08:36 PM
redford's Avatar
redford
FTE Leadership Emeritus
He filed suit against Ford because he got a 2003 Power Stroke (7.3L?) engine in place of the 2004 6.0L Power Stroke ?
Or....did he get a 6.0, but a 4R100 transmission?
I'm confused.
Old Jul 10, 2008 | 09:31 PM
bpounds's Avatar
bpounds
It seems fairly clear to me given what we know about the '03 6.0. Ford had problems with the first generation 6.0 '03 motor. But some of the first generation motors were also used in '04 trucks. All of that we at FTE know.
This buyer avoided a first year engine as many of us do, but when he bought a second year truck he still got a first year engine.
He feels Ford should have fixed the motor problems after the first year experiences.
I'm not saying I agree with his legal standing, but I think that explains it in a nutshell.
Bill
Old Jul 10, 2008 | 11:43 PM
BLK94F150's Avatar
BLK94F150
I'm confused.
He got an 03 6.0 in an 04 truck. He didn't want the 03. The 7.3 was installed until 2003.5. The 6.0 went in from 2003.5 until 2007.
Mike
Old Jul 11, 2008 | 06:34 AM
glsurratt's Avatar
glsurratt
This case is along the same lines as the case against GM a couple decades ago where they were sued for putting "Chevy" engines in either Oldsmobiles or Buicks. People were upset because they paid for the upscaled GM product and felt like they got the inferior engines.
Old Jul 11, 2008 | 07:08 AM
HeavyTow's Avatar
HeavyTow
Would an 05 PSD that was build in Feb. of 2005 be likely to have any of the early engins in it? How would you know the difference?
HeavyTow
Old Jul 11, 2008 | 07:41 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
No, it's not possible for an '05 truck to have an '03 engine from the factory. All of the '03 engines were gone after the first quarter of 2004 production.
The first quarter of '04 production had early engines because that's the way it was scheduled. International didn't have the '04 changes ready to go at the start of '04 production, and this was known far enough ahead of time to know to continue building '03 level engines.
Old Jul 11, 2008 | 07:46 AM
dkf's Avatar
dkf
What was the build date of his 04'? His truck was probably built in 03'. There are a lot of people whos 6.0l have given them problems and the truck and engine is not an 03'. Seems to me he should quit his whining and just unload the truck. If he can afford the lawsuit he can afford a new truck.
Old Jul 11, 2008 | 07:57 AM
HeavyTow's Avatar
HeavyTow
Engine Break points
Mark, thanks for the info. Were there any other break points for major adjustments to the 6.0? Say 05 vs 06 vs 07?
HeavyTow
Old Jul 11, 2008 | 08:07 AM
utahtom's Avatar
utahtom
Heavy Tow,
Since you asked, a change occurred called commonization on the 06/07 versions as follows:
Subject: 2006 6.0L Diesel Power Stroke Cylinder Head Commonization
Effective Date: Ford Production Assembly Plants - January 11, 2006
Kentucky Truck Plant (Super Duty) & Lorraine Assembly Plant (Econoline)
Description
Changes are being made to the 6.0L diesel cylinder head, head gasket, crankcase block, rocker
arm carrier and injector hold down clamps for the 2006 Super Duty and Econoline Program. The
action is taking place to facilitate/communize the International manufacturing process for the
upcoming 6.4L program. The 2006 6.0L used in Ford vehicles after January 11, 2006 are being
referred to as "Commonization Engines".
Part number details are provided on a separate excel spreadsheet.
Figure 1 - New cylinder head
1. Carrier boss bolt holes M10 x 1.5
2. Injector clamp bolt holes (relocated)
The new cylinder heads have several casting changes including a slight injector clamp bolt hole
relocation (2, figure 1) and the carrier boss bolt hole size and location changes (1, figure 1). New
cylinder heads also use 32 mm cup plugs replacing the old 28 mm cup plugs.
The cylinder head gasket is also new to accommodate the new 20mm cylinder head location
dowels. Pre commonization head use 18mm dowels
Note: At this time the new cylinder head assembly is not interchangeable with the previously level
head.
Figure 2 – Previous Level Cylinder Head
1. Carrier boss bolt holes M8 x 1.5
2. Injector clamp bolt holes (original locations)
Note: The previous level cylinder head assembly is not interchangeable with the new head.
Figure 3 - New Block Assembly
The new crankcase (block) uses two 20mm cylinder head locating dowels per head.
The old crankcase (block) uses two 18mm cylinder head locating dowels per head.
Note: The new and old block assembly is not interchangeable. This affects replacement of all 6009
short blocks and the 6010 bare blocks.
Rocker Arm Carrier:
Figure 4 - New Rocker Arm Carrier
Casting changes to the rocker carrier provide increased clearance for new injector hold down
clamps (figure 6). The new carrier also uses only 2 bolts and locating dowels to attach the carrier
to the head.
The new rocker carrier is serviced in a Rocker Arm Carrier Kit which includes the rocker carrier
cover, gasket and necessary dowels.
Note: The new and old rocker arm carrier kits are not interchangeable.
Figure 5 – Previous Level Rocker Arm Carrier Kit
The old rocker arm carrier uses 4 attaching bolts to hold the carrier to the old cylinder head (figure 2).
The previous rocker arm carrier is also serviced in a kit which includes the rocker carrier cover,
Note: The previous level rocker arm kit is not interchangeable with the new kit and will remain
available for service.
Injector Hold Down Clamp:
Figure 6 - New Injector Hold Down Clamp Assembly
The tail end of the new injector hold down clamp is being reduced to avoid interference with the
rocker arm carrier wall. Injector hold down clamp bolt torque will increase from 24 lbf·ft to 25.8 lbf·ft
and bolt head size will increase from T40 to T45.
Note: The new and old injector hold down clamps are not in interchangeable.
Figure 7 – Previous Level Injector Hold Down Clamp Assembly
Note: The new and old injector hold down clamps are not in interchangeable. The old injector hold
down clamp will remain available for service.
Old Jul 11, 2008 | 08:26 AM
krewat's Avatar
krewat
I'll leave this for now, but keep it simple - no discussing possibly joining the case, or anything like that.
Thanks
Old Jul 11, 2008 | 09:50 AM
HeavyTow's Avatar
HeavyTow
Thanks UtahTom
Sounds like an almost complete redesign for 06. So correct me if I'm wrong. After the improvements in early 04 there were no significant changes to the 6.0 PSD until the 06 Communization.
HeavyTow
Old Jul 11, 2008 | 11:09 AM
superduty4x4's Avatar
superduty4x4
Sounds to me like the guy needs to get the sand out of his shorts and move on.
17 Oaks
May 29, 2017 12:31 PM
Tugly
May 26, 2017 02:00 PM
AZFordLover
May 26, 2017 01:57 PM
troverman
Nov 16, 2016 02:42 AM
origcharger
3.0L Powerstroke Diesel
111
Jan 8, 2009 10:57 AM
