Dash Cover Removal
Old Jul 9, 2008 | 07:32 AM
danskool's Avatar
danskool
Go Bills !
Dash Cover Removal
Ok. Stumped. How do i get this cover off. Want to start working on TC Lock Mod. I don't want to scratch up and make it looked hacked. I tried with a butter knife/etc. Poking and such. no luck. Can't reach it from the underside.
Thanks in advance.
Old Jul 9, 2008 | 07:38 AM
f250rangerexplorer's Avatar
f250rangerexplorer
it just snaps in there. it may feel as if something is going to break as you pull it away from the main part of the dash. start near the headlight switch side and work your way across poping the snap clips. It was hard to do the first time cause i thought i was going to break it but it didn't. I don't remember if the stock stereo comes out at the same time or not. i did this when installing a aftermarket stereo. Hope this helps...
Old Jul 9, 2008 | 07:57 AM
Pocket's Avatar
Pocket
1) Pull out the stock stereo. You'll need a removal tool, and you can find that at Wal-mart or some car stereo shops. The removal tool is two U-shaped metal pieces that hook in on each side, pull outward, then slide the stereo out. Some have been lucky with just a coat hanger, but I tried it and it didn't work on mine.
2) After the stereo is out, look at the upper lip where the stereo was. There are two screws. These are the only 2 screws that hold the dash cover on. Remove the screws, and the rest of the dash cover unclips out. Pull a section at a time.
3) Don't forget about the electrical connectors mounted on the dash cover. Unplug those if you plan to take the dash completely out of the truck.
4) Drink a beer. You're done.
Old Jul 9, 2008 | 08:18 AM
danskool's Avatar
danskool
Go Bills !
Holly Crapper. The hole cover needs to come off.
Ok. I will take a shot at it once i get the supplies i need, + beer. Thanks for the Instructions.
I was thinking this morning about, "probably have to pull the hole dang thing" You guys confirmed it.
I have used long nails before. I forget what size. 3penny?. for the radio. No problem getting that out.
Thanks again.
Old Jul 9, 2008 | 10:05 AM
SpringerPop's Avatar
SpringerPop
I don't believe that "panel" pops out. It's not a hole cover. I think it's just molded into the bezel.
This may be of some help to you:
SpringerPop's Upfitter Switches
Click on the thumbnail photos to enlarge.
It shows that part with the 4WD selector switch opening cut out directly from the panel. I made the vertical rectangular hole, but the other one beside it is from the factory. One of the photos shows the area where Ford apparently used a router bit to open this hole, and it has rather rough edges, not smooth molded ones.
Pop
Old Jul 9, 2008 | 11:24 AM
danskool's Avatar
danskool
Go Bills !
Just like with the others have said. With pictures.. EXCELLANT info ! And idea's to boot !
Sweet
Thanks
danskool
26
Jul 16, 2010 07:04 PM
danskool
18
Jul 30, 2009 01:43 PM
danskool
42
Jun 2, 2009 01:34 PM
danskool
16
Mar 16, 2009 06:33 PM
danskool
Aug 10, 2008 06:12 PM
