clutch??
Old Jun 29, 2008 | 03:12 PM
Farmall05's Avatar
Farmall05
thats what I did, But afer bench bleading it I put it in the truck and now I cant get it to pump up right it has plenty of pressure clutch works fine now but you have to bring the peatal back up with your toe
Old Jun 29, 2008 | 07:36 PM
Farmall05's Avatar
Farmall05
ok now this is weird The last post I maid was when the rain started it just stoped and I went out and it has enought pressure to bring the peatal back up but has too mutch free play in the peatal when a few hours ago I had about 1 1/2 ins any thought any one, the master cyd rod was and is still un hooked started raining again
Old Jun 30, 2008 | 04:45 AM
Lazy K's Avatar
Lazy K
Sounds like you still have air in the system. Is there a clutch pedal return spring that you can see? Anyway bleed the system again.
Old Jun 30, 2008 | 06:14 AM
Farmall05's Avatar
Farmall05
ya there is a return spring I blead it alot 1 qt of fluid still no luck
Old Jun 30, 2008 | 06:45 AM
Farmall05's Avatar
Farmall05
hey 1 thought I was wandering since I have it back to 1 in of free travel and it is exactly how it was before could it be the slave cyd? fust a thought before I start pulling my hair out
Old Jun 30, 2008 | 07:15 AM
Lazy K's Avatar
Lazy K
Wow! Hard to take in. The only way a slave cyl. can fail is if fluid gets past the piston seals instead of pushing the piston out. If this was the case you would see the leak and notice a loss of fluid. With 1in of free play in the pedal, a new master cyl. and the system bled you should be getting the full shot of fluid going to the slave cyl. when the pedal is depressed so why are you still only getting 1/4in movement of the slave cyl. rod? Does the pedal feel "hard" all the way down? No spongy feeling? When you checked the free play at the end of the throwout lever did you push it real hard towards the slave cyl. before measuring it?
Old Jun 30, 2008 | 07:50 AM
Lazy K's Avatar
Lazy K
OK, another thought. I have heard of the flexi brake hoses on some cars softening with age and starting to bulge, causing a low brake pedal. Never heard of it happening with a clutch system but may be worth checking. Have a good look at the flexi hose when someone pushes the clutch pedal down. The hose wall should not flex at all. If all that fails you could try posting this problem on the pre-powerstroke diesel forum, there are a lot of very smart guys there. Please post back what you find and I will help more if I can.
Old Jun 30, 2008 | 12:48 PM
Farmall05's Avatar
Farmall05
well the thought on the line bulging under pressure I thought about that but is all newer line no rust or any thing so I threw out that Idea. I did drive the truck this morning had to deliver a tractor I promised I would first thing this morning and the more I used it the better it got till it sat for a while then back to the same thing hard to get in gear, im going to try to blead it again, I did look at the slave cyd its dry exep where The bleader is so I wouldnt say its leaking I was thinking it could be getting week enought to not work corectly but after this morning drive Im going to bead it some more and see what happens I will let ya know how I make out thatnks for all the help
Old Jul 3, 2008 | 06:43 PM
Farmall05's Avatar
Farmall05
well it was the slave cyd was fine for a few days and then it went back to the same thing so blead it half a dozen time and no change so I changed the slave cyd and no more problems thanks for all the help
crash1
44
Mar 7, 2012 06:32 PM
884x4broncoII
Jan 21, 2008 12:58 AM
bamacountryboy
1983 - 2012 Ranger & B-Series
17
Nov 27, 2005 09:49 PM
DT 466Man
1997 - 2003 F150
Sep 21, 2005 12:58 PM
odie780
Mar 2, 2004 07:15 PM
