Air bag light blinks!!!
Old Feb 15, 2018 | 08:00 PM
  #91
Yogi54481's Avatar
Yogi54481
Originally Posted by projectSHO89
You managed to blow the light bulb in the PAD switch, probably due to banging the seat against the dash just to the right of it's center. Or, just bad luck and timing....
Thanks! Before I tear out the whole dash, is it an easy replace for a simple man? I guess I can always live without the light on if the airbags still work...
Old Feb 15, 2018 | 09:13 PM
  #92
RyGuy76's Avatar
RyGuy76
I was just reading this and learned something new about the blinking airbag light. Anyway 1997 Expedition code 32 which from the other symptoms, no horn or cruise, I have figured it is the clock spring. My question is since my Expedition has a navigator steering column, will it be the same clock spring or not?
Thanks
Old Feb 16, 2018 | 06:36 AM
  #93
projectSHO89's Avatar
projectSHO89
The PAD switch doesn't require the dash to be torn out.
When the airbag light is on, the airbag system is OFFLINE. That means they will NOT work in the event of an accident in which they should have deployed.
Electrical Systems/Wiring
39
Mar 8, 2022 08:55 AM
Flyct
Dec 18, 2017 12:12 PM
NICKSAN
Sep 30, 2017 04:55 PM
couverley
May 7, 2017 11:41 AM
Jamespappleton
Mar 1, 2017 07:45 AM
