Air bag light blinks!!!
Old Sep 22, 2010 | 12:24 PM
  #61
Araltd's Avatar
Araltd
Originally Posted by alloro
Yes, unless you know where the airbag module is. If you do, you can unplug the connector and check the wires with a meter for continuity. Also, just in case you weren't aware; that cap that plugs into the connector under the seat is actually a resistor. The reason you're getting a code 36 is that the airbag module cannot detect that resistor. The problem could be as simple as that resistor being no good. If it fits, you could try swapping it with it's passenger side counterpart. If the resistor is the problem, the code 36 will go away and a code 37 will appear.
AH! Excellent advice! I will try that later tonight, after work! THANK YOU!
Old Sep 22, 2010 | 12:31 PM
  #62
TexFinn's Avatar
TexFinn
Originally Posted by fivestarairbags
The code 33 is indeed a driver side seatbelt connector but can't be fixed by replacing the seatbelt.
Hold on... You sure about the side? Kind of interesting that the code the shop gave me (B2292) was supposed to be the passenger side.
Old Apr 13, 2012 | 10:31 PM
  #63
real_texan's Avatar
real_texan
I have a code 49. On a 2003 explorer. Can someone help me out. Also I have a door ajar light that won't turn off and the interior lights are always on thanks
Old Apr 14, 2012 | 01:53 AM
  #64
alloro's Avatar
alloro
You'd get better help in the Explorer forum, this is the Expedition forum.
Go here: https://www.ford-trucks.com/forums/forum32/
Old Jan 30, 2013 | 05:40 PM
  #65
GasV10guzzlerf250's Avatar
GasV10guzzlerf250
Air bag flashing could have been expensive.....
I just wanted to say thank you alloro for your comment. Saved me about 300 plus bucks to have a mechanic plug my passenger side plug back in!!!
Old Jan 31, 2013 | 10:19 AM
  #66
alloro's Avatar
alloro
Glad to help. I'm always willing to take money out of the hands of overpriced grease monkeys.
Old Sep 7, 2015 | 11:07 PM
  #67
kkaz642's Avatar
kkaz642
I posted my own thread and didnt get but one response that didnt help. Im getting code 32 flashing, I was told that code #32 is the clock spring. But my horn works fine, I was told that the clock Spring is fine if the horn works. i did take it apart and it was in good condition no breaks or bends. So... Any other ideas what can cause code #32?
Side note i also checked the wires from the passenger side to the driver side and they where fine, no cuts or breaks the wires and where plugged in tight. idk what else to do.
Old Sep 8, 2015 | 12:05 AM
  #68
Autoarcheologist's Avatar
Autoarcheologist
I have had other cars where the horn worked with a bad clockspring. Buying an airbag test resistor might help.
I can look up the diagnostic procedure if you need it.
Old Sep 8, 2015 | 08:53 AM
  #69
alloro's Avatar
alloro
You were given bad advice. The airbag and horn circuits use different contacts within the clock spring. Based on the advice you were given, if your kitchen light doesn't work the wall switch must be good since the bathroom light wall switch still works and that just isn't so.
Old Sep 8, 2015 | 10:35 AM
  #70
Skauber's Avatar
Skauber
You can test the clock spring, but make sure you disconnect the battery and wait 10-15 minutes before messing with the airbag. Remove the airbag when probing wires, disconnect it as soon as you can access the plug to it and unbolt it from the steering wheel, place it face UP in a safe location. If it should accidentally deploy, it will not launch itself like a projectile if it's facing UP.
Old Sep 23, 2015 | 05:40 PM
  #71
dmcenery's Avatar
dmcenery
air bag light blink
min blinks 3 then 4 on an 06 F150. Any idea of cause?
Old Sep 24, 2015 | 09:41 AM
  #72
alloro's Avatar
alloro
Code 34 is a loss of electrical contact with the driver's airbag. The most common cause of this is a worn clock spring.
Old Mar 29, 2016 | 01:18 PM
  #73
Fd jennings's Avatar
Fd jennings
Help f250 I removed the two front seatsand now my airbag light is own code 25
Old Mar 29, 2016 | 06:45 PM
  #74
alloro's Avatar
alloro
Code 25 usually means the passenger side airbag switch is turned to Off.
Old Apr 3, 2016 | 12:21 AM
  #75
2001NaviA4WD's Avatar
2001NaviA4WD
I have a 2001 Navi. My airbag light just recently started blinking on me. It gives me 3 flashes, 2 flashes, and repeats that 5 times. I saw in an earlier post that the code may mean the steering wheel clock spring may be bad. Is that something I can fix? Where is it located?
