Air bag light blinks!!!
Old Jun 23, 2009 | 11:24 AM
04markIII's Avatar
04markIII
my airbag code wouldn't come up in my xcal 2, which is basically the same thing they use, but go for it. maybe it will give a code.
Old Jun 23, 2009 | 01:34 PM
mikekassouf's Avatar
mikekassouf
The machine didn't come up with a code. The guy said it would just pick up engine code problems. Back to square one. I am going to disconnect the battery for about 10 to 15 minutes tonight and see if that clears it. Then it might be to the dreaded dealership
Old Jun 23, 2009 | 01:47 PM
04markIII's Avatar
04markIII
where are you located?
Old Jun 23, 2009 | 01:49 PM
mikekassouf
Birmingham, AL
Old Jun 23, 2009 | 03:04 PM
mikekassouf
Called the dealership and this is what they said. It is a passenger side airbag canopy fault.
Of course, they said to bring it in.
Old Aug 18, 2009 | 11:42 PM
TexFinn's Avatar
TexFinn
Bringing an old thread back up again...
The airbag light blinks three times in a row a few times until it stays lit, so I'm assuming it means code 33, right? Now..., I found this explanation regarding Expeditions:
Code: 33
Passenger Air Bag Circuit
Resistance High
Is that correct diagnosis? I also saw some other explanations for Explorer/Mountaineer and others.
I've read that many people have been able to clear various of these airbag codes by wiggling the connectors here and there. Would that be the correct remedy in the case, too? If not, then what?
Old Aug 19, 2009 | 07:50 AM
04markIII's Avatar
04markIII
so, it blinks 3 times, takes a short pause, blinks 3 times again, and then takes a long pause and then repeats?
Old Aug 19, 2009 | 11:16 AM
TexFinn's Avatar
TexFinn
Yup.......
Old Aug 19, 2009 | 06:23 PM
projectSHO89's Avatar
projectSHO89
No, it isn't. There are different LFC tables for different year's models. Some of the codes have been used on certain models but may have a different meaning on another.
On your vehicle, an LFC 33 indicates a fault with circuit for the driver's side safety belt pre-tensioner. Often, these failures are due to intermittent wiring harness connections, often at the RCM.
Warning: Messing with the SRS system can ruin your day if you screw up. If you're not sure what you're doing, take it to a mechanic who does. This is NOT a trivial warning.
Depower the system. Access the RCM (may require seat removal depending on interior trim). Inspect and reseat the connectors. Re-power the system and see if the fault clears.
Old Aug 20, 2009 | 11:35 AM
TexFinn's Avatar
TexFinn
That sounds interesting... Messing with any of the airbag stuff is always a bit risky, so we'll see.
Is the RCM inside the B-pillar trim, or is it under the seat?
Old Oct 12, 2009 | 06:50 PM
TexFinn's Avatar
TexFinn
Still haven't done this, but since my wife keeps on nagging about it, I guess I should... Not to mention the possible safety issue, of course.
Anybody have any more insight to this one?
Old Oct 12, 2009 | 06:55 PM
alloro's Avatar
alloro
Code 33 means the circuit to the passenger side airbag is broken.
Old Oct 12, 2009 | 07:01 PM
  #28
alloro's Avatar
alloro
Oh and...Take a look under the passenger seat for a 2-wire connector (sometimes white tipped) and make sure it's plugged in tight. These connectors have been know to get knocked out from items being shoved under the seat.
Old Oct 12, 2009 | 07:08 PM
  #29
TexFinn's Avatar
TexFinn
Really? So you are saying my initial finding regarding the meaning of the code is indeed correct (post from 8/18 above)?
Damn..., I'm getting confused...
Old Oct 12, 2009 | 07:25 PM
  #30
alloro's Avatar
alloro
I never said you weren't correct.
In your earlier post from today you said, "Anybody have any more insight to this one". My insight was to reaffirm your suspicion.
Go back to the first page and look at posts 2 and 3 of this thread. Someone else with airbag code 33 fixed the problem simply by reinserting the connector under the passenger seat.
