scan reading questions
Old Feb 15, 2018 | 11:51 AM
jcweis1's Avatar
jcweis1
1998 5.4 expedition that threw a p0402 and a p0306. Replacing the DPFE sensor and coil for cyl 6.
As I was checking the running scan the o2bisi(v) reading had a ? mark and the readings showed as:
.80-.855
.095-.860
.095-.790
.085-.825
are these readings normal? If not could it have something to do with the DPFE and miss fire?
thanks
Old Feb 15, 2018 | 02:47 PM
pdqford's Avatar
pdqford
Not sure which ob2bisi reading is which, but that first one appears to be stuck rich as in trying to fuel the excess oxygen detected from the misfire. But #6 is on the driver’s side.
Old Feb 15, 2018 | 07:14 PM
projectSHO89's Avatar
projectSHO89
Try figuring out what it is you're actually looking at, we have no idea what you actually saw since what you posted is nonsensical.
Old Feb 16, 2018 | 09:45 AM
jcweis1's Avatar
jcweis1
Sorry it did not make much sense.
I have a cheap harbor frt scan tool and really do not know how to use it other than read the scan codes.
I had the scanne reading live data with the engine running and noticed one listing of o2bisi(v) had a ? mark beside it.
Not knowing what o2bisi(v) is - I thought I would ask and list the readings. I am not sure if these readings are something related to P0420 and PO306 and even if the readings were within an acceptable range.
Thanks
dave6666
Modular V10 (6.8l)
Jun 11, 2019 11:08 AM
ItsAndy
Mar 18, 2016 04:26 PM
Bootlegger's Deluxe
Modular V8 (4.6L, 5.4L)
Mar 12, 2016 08:51 PM
HappySailor
Apr 9, 2015 08:54 AM
snb73
Jan 31, 2009 01:20 PM
