Help with injector circuit 5 low
Old Jun 24, 2008 | 10:30 PM
fast96powerstroke's Avatar
fast96powerstroke
I am working on a 2001 PSD that has an intermittent code for #5 injector circuit low. I have a scan tool and have pulled the codes and checked the icp and ipr and dont see anything out of range. the only code is for #5 injector. I pulled the uvc harness and the valve cover and replaced them and the problem still exists. I have also swapped idms with a known good one and it hasnt changed. The problem has become more intermittent. I even swapped injector solenoids with another one. Any help would be appreciated!
Thanks
Old Jun 25, 2008 | 05:17 AM
danskool's Avatar
danskool
Go Bills !
I'm a dummy to injectors here. But maybe stick number 5 injector in the number 3 hole and the number 3 to the number 5 hole. See if you get a #3 code. Just a thought. I may be way off base here.
Old Jun 25, 2008 | 08:44 AM
Pocket's Avatar
Pocket
That will tell you in a hurry if it's an actual injector problem, or a chaffed wire somewhere.
Old Jun 25, 2008 | 09:39 AM
SuperDoodie's Avatar
SuperDoodie
You guys beat me to it! Thats what I was gonna suggest..
Old Jun 27, 2008 | 12:04 AM
fast96powerstroke
Thanks I will try that as soon as I can get the truck back in my shop. Anyone have any of the resistance values of the injector solenoids. Or any other electrical tests that I could try? Thanks for the help
Curtis
Old Jun 27, 2008 | 07:38 AM
danskool's Avatar
danskool
Go Bills !
Good post with info here. https://www.ford-trucks.com/forums/5...injectors.html
Old Jun 28, 2008 | 02:33 PM
fast96powerstroke
ok thanks im goin to try swapping injectors this week and will let you know the results. Thanks for the help.
Old Jun 28, 2008 | 02:59 PM
tjbeggs's Avatar
tjbeggs
The solenoids should have about 3 to 3.5 ohms testing thru the valve cover connector. You can also test the wiring with an ohm meter from the valve covers to the IDM connector. Not easy to get to the IDM there but from the sounds of you have already been there once.
EDIT- also one key areas to check on the main engine harness is where it goes over the driverside valve cover. The harness commonly gets chaffed there.
Old Jun 28, 2008 | 03:33 PM
fast96powerstroke
Thanks TJ I have checked the solenoid resistance with it off the injector and it was 2.8 ohms. The uvc wiring and gasket are new. What should the resistance be without going thru the harness? I thought it should be around 2.9 or 3 ohms. Yeah Ive had the IDM out and modified it already. Ill check the harness for any chaffed wires too. Ive worked on these for many years and Ive never seen one act like this.
Does anyone know if the wiring colors for the idm and injector circuits are the same for a 97 and a 2001
Old Jun 28, 2008 | 05:15 PM
tjbeggs's Avatar
tjbeggs
2.8 ohms is good
cylinder #5 is a tn/bk wire for your truck. Give me a few minutes and I can post some graphics that will be helpful but its time for dinner right now.
Old Jun 28, 2008 | 05:56 PM
tjbeggs's Avatar
tjbeggs
this isn't great quality but if you click on it you can then zoom in to it in my Webshots
and another
Old Jun 28, 2008 | 06:27 PM
fast96powerstroke
Thanks very much Ill do an ohm test on the wiring harness between the idm and the plug at the valvecover and see what I come up with. Ill be sure and post my results as soon as I can get the truck back in my shop.
Thanks for all the info and help
Curtis
Smokin Performance
96 PSD 6Pos DI Chip,Custom air intake,2002HPOP,IDM Mod
Switchable 10K Mod and Hybrids to follow soon
BRay09
Feb 5, 2012 06:54 PM
fixxxer-upper
Dec 30, 2011 09:53 PM
Ricson
Oct 17, 2011 08:22 PM
budman5201
Oct 3, 2011 05:12 PM
06powerstroke06
Feb 25, 2009 12:47 PM
