Ford fuel additive
Old Jun 19, 2008 | 01:30 AM
bocomojoe's Avatar
bocomojoe
Ford fuel additive
Does annyone know who makes the Ford diesel additive that is sold at Ford dealerships? I'm almost sure that I've seen an answer somewhere but l can't find it.
Old Jun 21, 2008 | 01:54 AM
dc3655's Avatar
dc3655
I've heard somewhere before, but can't remember right now. Why are you asking? I can say that I've been running it for the last few thousand miles and my truck runs great and I've been getting good fuel mileage. I was running Stanadyne before, but the Motorcraft supplement is cheaper and there wasn't any drop off in performance so I would recommend it.
Old Jun 21, 2008 | 02:47 AM
bocomojoe's Avatar
bocomojoe
Thanks for the reply. I wanted to hear others experance with the Ford additive. I was wondering if it had any advantage over PS or Stanadyne.
I use Power Service now it seems to be OK. I use it more for lubrication and to keep my EGR operational. The Ford techs have told me that the best things to do to keep it working properly was to: 1. do not idle, 2. use an additive to increase the cetane, and 3. work your truck hard. (higher cetane rating should inprove mpg also.)
I thought that maybe the Ford additive was made by Powerservice or Stanadyne. It is more expensive than PS.
The Ford additive is $7 to $8 for 16 oz. while Power Service is about $13 for 96 oz.
Old Jun 21, 2008 | 09:12 AM
bismic's Avatar
bismic
I read a long time ago that it was Stanadyne. However, after reading that, I did a little research to get some verification and could not find any.
Old Jun 22, 2008 | 06:20 PM
Dieselmanor's Avatar
Dieselmanor
FTE Sponsor
I've heard that they just relabel the Stanadyne, but I honestly don't know if that's fully accurate. I do know that Stanadyne does have Fords approval, as well as International, Navistar, et al. I've used it in my 7.3L for years now and have never had a single injector failure. Can't say it was the Stanadyne that's responsable for that. I do know that it does help with fuel economy. I gain .63 MPG when I use it. At today's fuel prices it wouldn't make sence for me not to. The break even point is 2.60/gal of diesel fuel. So if fuel costs me more than 2.60, I'm saving money.
We stock it in single One Shot 8oz bottles, 16oz bottles, and 1/2 gallon jugs too.
Old Jun 22, 2008 | 06:39 PM
Sarge261's Avatar
Sarge261
I have used it in both of my 6.0's. I use the Cetane/Performance improver in the summer and the anti-gel/Cetane improver in the winter. My tech. also said the same as above, reduce idle, run an additive, & work it hard.
Sarge
Old Jun 22, 2008 | 08:34 PM
Bulldog66's Avatar
Bulldog66
I use it mainly because I can get it a little cheaper.
I've used it for 25k+ miles and not a single fuel related issue. I do, however, change my filters on time, every time.
The biggest problem I have is occasionaly, after backing the frame mounted filter cap out, it distorts the plastic threads and it don't want to go back on. So, I've just purchased a couple extra caps for those "d'oh" moments and I'm not dead in the water because of a filter cap.
Cheers.
Old Jun 23, 2008 | 08:12 PM
steveo1950's Avatar
steveo1950
Dealership I bought mine at HIGHLY recommended either Motorcraft or Stanadyne. I have never used Power Service. I have changed to a FULL synthetic engine oil for diesels after 25,000 mile break-in. I use Valvoline premium blue EXTREME. If it isn't extreme, it isn't full synthetic. Dealer said if I could afford it the Synthetic would be the best. So ever 10,000 miles or so I rob a bank and buy some oil!
Old Jun 24, 2008 | 12:19 AM
cartmanea's Avatar
cartmanea
Even with good synthetic, 7500 miles is about all you should run before it shears down too much.
k_conner
47
Jul 11, 2009 09:14 AM
mhays2
Mar 8, 2009 07:09 PM
lazyscholar
Jan 26, 2008 11:56 PM
lpbaca
Mar 29, 2005 08:16 PM
TDELONG83
Jul 26, 2004 09:00 AM
