Sponsored by: Innova
subs in 99 sd xcab
Old Jun 1, 2002 | 10:56 PM
V10_rin_tin_tin's Avatar
V10_rin_tin_tin
subs in 99 sd xcab
what do yall suggest for putting 3 10" subs in the back of an extended cab f350?
Old Jun 3, 2002 | 09:26 AM
odinmurphy's Avatar
odinmurphy
subs in 99 sd xcab
Not sure how much space you will have in the back of the extended cab. Behind the seat of my 2000 CC I had enough room for a box holding 4 10"s with .6 cubic ft of air space per chamber. Make sure that what ever sub you buy will be able to run in the box you have made. The first 10"s I put in my truck were Cerwin Vegas. They did not sound good due to the low air space I had. I swapped them out for some premiers. Huge difference.
Good Luck
Murph
Old Jun 3, 2002 | 11:27 AM
akford351's Avatar
akford351
subs in 99 sd xcab
I think that a pair of 12's will sound better than three 10's. They will get much deeper. Are you going to be putting them on the seat?? My dad has a 2000 F-250 (its an XL and the rear seat doesn't fold down...not sure if the XLT seat does)... Anyhow... The three tens MIGHT get louder, but I'd mob a pair of 12's I recommend Alpine's (Type S or R both good), Infinity Kappas, and Cerwin Vega HED's are good subs for only about 100 bucks. Good luck
Ray
Old Jun 3, 2002 | 04:46 PM
odinmurphy's Avatar
odinmurphy
subs in 99 sd xcab
I agree with AKFORD. I know that 12"s would sound better in my truck. The problem I ran into was that I just didn't have the mounting depth to put 12's behind my seat. I know this sounds like common sense, but just make sure that whatever you are going to do, is going to fit in your truck. More than once I have purchased something I thought would fit, and it didn't. So then comes the modifications to make it fit. Then you end up with rattles and less than perfect sound.
Good Luck
Murph
Old Jun 5, 2002 | 01:53 PM
rusty9's Avatar
rusty9
subs in 99 sd xcab
if you need 3 go for it. my suggestion is to look into a rear seat lift kit. i put one in my 88 so i had room for my amps, crossovers and sub box without hindering the function of the seat or passenger room. i got mine at Calmar industries.
Rusty.
Old Jun 5, 2002 | 02:43 PM
devil421's Avatar
devil421
subs in 99 sd xcab
akblackfoot
Jan 6, 2017 11:36 AM
SneakyF350
6.7L Power Stroke Diesel
Nov 23, 2010 02:55 PM
RyanMiller
Oct 27, 2004 09:26 PM
Vegas-V10
Modular V10 (6.8l)
Jan 8, 2004 03:36 PM
CobraXP
Jan 3, 2003 10:50 AM
